Was there ever an answer to the question of whether the current (JS-based rather than Flash) version of the FusionCharts suite isn’t close to being a drop-in replacement for the old Flash version? Sorry, I may have missed it. Or is it a licence/cost issue?
IIRC there was an answer but I guess it got lost in the server disaster. My thought would be that the license cost would be a show stopper.
Maybe a crowdsource/challenge of programmers to take WDL and build either an HTML5 or Java replacement that has a local configurator program like WDL has now. Make it easy for anyone to set up a live page and at a reasonable cost.
Unfortunately the potential crowd for this app is pretty small
Well I guess it wont be that bad. I already have the possibility to choose units, I will add language and then I can also make it possible for the user to customize colors, size etc.
If you have any suggestions let me know, I will post here a link to an “alpha version”, I know there is still a lot of work ahead, but take it as a starting point.
Note:
Since I use meteobridge and do not have my station running WD and clientraws generated, the below link uses clientraws of one of the users here on the forum who was that kind to provide me with a link. But because of that I set the update interval to relatively large value so that I dont load his server too much. THe interval however can be set to anything, even 1s for example.
I must say that’s really attractive. It would be welcome on my website!
Well I mentioned this in another thread as well, but I will also make several designs so that you can choose and of course you can set units, language, colors, size, solar gauge is optional, you can set up update intervals.
Right now I just want to make sure the data is correct and it uses the correct clientraw fields and that the script itself works. But hopefully it should not take too long.
Important thing is that it uses ONLY clientraws, no database, so basically all you have to do is upload to server, specify path to clientraw, set update interval and you are done.
nice Was the cloudbase.png not included in the zip?
No.
That’s a big cloud 8O
Yes But it will resize in the file and I have most of my icons in higher resolution so that I can use them bigger if necessary, it is still just about 50 kb anyway
I’ve just tried one of the samples on my mobile phone and I am not sure it works well on that size screen, it does not yet compare well with the formatting of the Steel Gauges, yes I realise this is work in progress and I hope it will continue and improve. My main reason some time ago to get Steel Gauges working was for mobile devices with no flash, so I hope this becomes as good on those devices.
But Julian must presumably have previously struck a deal with InfoSoft to use the FC, widgets etc suite in the first place. (Someone please correct me if I’m wrong, but my ageing recollection is that WDL uses the FC suite as its main presentation engine.) So the question really boils down to why this deal cannot be continued on presumably similar terms, but obviously now for the JS-based version of the suite.
I think the issue here is that we want anyone to be able to view our web pages without having to do anything with their devices, its OK for those with the skills but the vast majority dont have them. If you have the skill and it works then fine. However we need to be able to migrate to things which work on ALL platforms without user intervention on their devices since Flash will at some time in the future die completely, many people on desktops have it turned off these days because it is not very secure.
I can only test android, with Android I see my gauges but nothing for wdl, no flash support
One note, it loads 1.5 MB of files 8O Thats waaay too much, ie. icons whats 100 KB in size each are just too much expecially for mobile devices with limited bandwidth. Its nicely responsive tought but a few gauges are too wide for 320 px width what many smarthphones have… Btw. why do you not use css-sprites (combine all icons to one image) to get down the http-requests?
