However I do want to say that this does not mean I will no longer participate on this forum and no longer watch this thread. I will and in fact in some cases it would be more appropriate to use this thread.
Given I do not have/use WD myself, if your question is not really related to MT as such but rather some problem with WD (setting up MT updates, exporting logs etc.) it would be better to ask here because such question is likely to be better answered by Brian.
I am having problems getting my google maps to show up over the past few months, I have tried setting up a new API key on several occasions and today I have generated yet another key (and deleted the old ones on the API dashboard). I have tried various combinations of .philsweather.co.uk/ with the dot at the start and without, putting meteotemplate/ after the / each time I have copied and pasted the new api code direct from google to the text document in the install folder, uploaded and checked that it is showing the correct code in the main set up page, but I STILL get the error message that google maps didn’t load correctly and to check the Java script console for details. How do I look at the javascript console? or can anyone help me solve the problem.
Here’s a link to a page that needs the map http://www.philsweather.co.uk/meteotemplate/plugins/issTracker/index.php
Hi Phil,
did you run the Main settings page?
The way this works is that the data from Txt file is saved to the config upon saving the Main settings, this is what the template then uses. So just changing it in the text file will not work because it will not get copied over to the main settings file (config.php).
yes I did see your comment in the Blog, as far as I remember they use a different data source, the plugin was created earlier, so it could be that its only included in one, otherwise Im sure I wouldnt omit it
Hi Jachym,
Sorry late response (been waiting for an example to arise).
1: Severe Weather Alerts : only happen now and then, so had to wait till one arose.
2: As this example was in WA(Western Australia) and I could not find a Meteotemplate user site in WA, I had to adjust my Block settings from ‘tas’ to ‘wa’.
3: Image (AWW0) : displays block showing WA Severe Weather Warnings:
4: Image (AWW1) : displays block popup showing Selected WA Severe Weather Warning:
5: Image (AWW2) : displays plugin showing no info when drop down bar selected for any WA Severe Weather Warnings: (On my Site).
6: Image (AWW3) : displays plugin showing no info when drop down bar selected for any WA Severe Weather Warnings: (On another users Site).
7: I think the issue is with the links as they differ in the path : http://www.bom.gov.au/fwo/IDZ00060.warnings_wa.xml It happens for all states (not just WA).
I have not had time to look at the difference in the Block (vs) Plugin Code, though envisage they must be different, when time permits over the next month I will investigate and let you know my findings along with possible code fix - if I do get to fix it.
Kind regards,
Tony
<item>
<title>
21/16:00 WST Marine Wind Warning Summary for Western Australia
</title>
<link>http://www.bom.gov.au/wa/warnings/marine.shtml</link>
<pubDate>Thu, 21 Sep 2017 08:00:54 GMT</pubDate>
<guid isPermaLink="false">http://www.bom.gov.au/wa/warnings/marine.shtml</guid>
</item>
<item>
<title>
21/17:42 WST Severe Weather Warning for Goldfields and parts of Gascoyne, Eucla, South East Coastal and Central Wheat Belt districts.
</title>
<link>http://www.bom.gov.au/products/IDW21037.shtml</link>
<pubDate>Thu, 21 Sep 2017 09:42:50 GMT</pubDate>
<guid isPermaLink="false">http://www.bom.gov.au/products/IDW21037.shtml</guid>
</item>
<item>
<title>
21/17:44 WST Severe Weather Warning for Lower West, South West, South Coastal, South East Coastal, Great Southern and parts of Central West and Central Wheat Belt districts.
</title>
<link>http://www.bom.gov.au/products/IDW21038.shtml</link>
<pubDate>Thu, 21 Sep 2017 09:44:54 GMT</pubDate>
<guid isPermaLink="false">http://www.bom.gov.au/products/IDW21038.shtml</guid>
</item>
<item>
<title>
21/15:06 WST Warning to Sheep Graziers for Lower West, South West, South Coastal, South East Coastal, Great Southern and Central Wheat Belt forecast districts
</title>
<link>http://www.bom.gov.au/wa/warnings/sheep.shtml</link>
<pubDate>Thu, 21 Sep 2017 07:06:05 GMT</pubDate>
<guid isPermaLink="false">http://www.bom.gov.au/wa/warnings/sheep.shtml</guid>
</item>
<item>
<title>
21/04:00 WST Fire Weather Warning for Goldfields and Eucla fire weather districts
</title>
<link>http://www.bom.gov.au/wa/warnings/fire2.shtml</link>
<pubDate>Wed, 20 Sep 2017 20:00:20 GMT</pubDate>
<guid isPermaLink="false">http://www.bom.gov.au/wa/warnings/fire2.shtml</guid>
</item>
<item>
a new version of Meteotemplate is now available. Over the past few versions I got rid of all changes directly in code and converted everything to GUI. With this version (apart from other new things) I also got rid of most FTP, unzipping etc. Just click and everything is installed/updated directly from my website to your template.
I had to look up Physalis so you get an extra point for that too :lol: My granny used to grow a variety of those, we called them Chinese Lanterns but I never knew the correct name.
setup data fields
show field numbers line:
date line 74
time line 32
test import keeps saying
-There seems to be a problem with the date and time. Either it has not been parsed correctly or it is a date/time in the future! Check the format you specified and also the actual values.-
Hi Ed,
I explained to you in 3 emails that you CANNOT use clientraw for data import! Clientraw has current conditions, not data import! Please read my emails too. You need monthly logs.
Clientraw WILL NOT work for data import. It is waste of your time trying it.
