Hi guys
[color=red][b]Plugin Update
Hi guys
Just a note to thank Brian and Jachym for the ability to create MT logfiles. My Router failed and updates were not happening. I was able to restore the data from Weather Display and I’m a happy camper.
Jay
[color=red][b]Block Update
Hi guys,
some changes to the WeatherFacts blocks (now a block), now also available for the U.K.
http://meteotemplate.com/blog/?p=3137
Enjoy
I try to import solar data with the new way in WD to meteotemplate, but I get some wrong data with the avg solar (solar data at night #-o )
My vantagelog seems to by good.
Can you look at this?
meteotemplatelog12017.txt (33.8 KB)
vantagelog.txt (123 KB)
the export routine uses the data file for the solar data and not the vantagelog
but you could try converting the vantagelog to solar data file
via action, convert WD logfiles to data files (convert solar log to solar graph)
Block Update - Weather Facts 2.0
Hi guys,
added:
Enjoy
Hi guys,
Plugin Update - Blog 2.0
Block Update - Weather Facts 3.0
Enjoy
Hi guys
[color=red][b]New Block
Block Update - Weather Facts 5.0
Enjoy
Meteotemplate - Questionnaire
Hi guys,
please help me with planning future development of the template by filling in a short questionnaire, it will only take a minute or two.
Is anyone else experiencing a problem with the Partner Station block? I have only one partner (my son) so cannot check against another Weatherunderground site. All his readings read 0, but if I go to the WU page it is recording there perfectly. Perhaps a change at WU? Or just a local glitch?
I think wunderground has problems
my data comes up with an error
https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=IFRANKLI1
WU is not working… the XML feeds are gone… surprise surprise…
Given that the WU forecasts have never worked for me (API or not), J
It seems to be back to normal. Phew! :oops:
Hi guys,
some of you were asking about my decision about Pro version, I explained my decision here:
Hi guys,
Block Update - Indoor 7.0
Hi guys,
as some of you maybe know already I changed my mind:
http://meteotemplate.com/blog/?p=3236
However I do want to say that this does not mean I will no longer participate on this forum and no longer watch this thread. I will and in fact in some cases it would be more appropriate to use this thread.
Given I do not have/use WD myself, if your question is not really related to MT as such but rather some problem with WD (setting up MT updates, exporting logs etc.) it would be better to ask here because such question is likely to be better answered by Brian.
Enjoy
I am having problems getting my google maps to show up over the past few months, I have tried setting up a new API key on several occasions and today I have generated yet another key (and deleted the old ones on the API dashboard). I have tried various combinations of .philsweather.co.uk/ with the dot at the start and without, putting meteotemplate/ after the / each time I have copied and pasted the new api code direct from google to the text document in the install folder, uploaded and checked that it is showing the correct code in the main set up page, but I STILL get the error message that google maps didn’t load correctly and to check the Java script console for details. How do I look at the javascript console? or can anyone help me solve the problem.
Here’s a link to a page that needs the map http://www.philsweather.co.uk/meteotemplate/plugins/issTracker/index.php
Aaaagh!!
Phil
