[color=red][b]Plugin Update
[color=red][b]New Block
[color=red][b]Block Update
Hi Jachym,
Thanks for all the updates, with ref to the Homepage / Blocks setup;
If I choose to apply a “Block Radius” value (say8px) in the Main Settings, it seems to be ignored when using a “multipleBlock” , example image attached; (has subBlocks too if that helps).
Oh and revamped my AusQuakes page too, which now uses a Tab to the Historic HeatMap page.
regards,
yes that is correct, multiple blocks work differently and it will not work for multiple blocks
Hi guys
Just a note to thank Brian and Jachym for the ability to create MT logfiles. My Router failed and updates were not happening. I was able to restore the data from Weather Display and I’m a happy camper.
Jay
Hi guys,
some changes to the WeatherFacts blocks (now a block), now also available for the U.K.
http://meteotemplate.com/blog/?p=3137
Enjoy
I try to import solar data with the new way in WD to meteotemplate, but I get some wrong data with the avg solar (solar data at night #-o )
My vantagelog seems to by good.
Can you look at this?
meteotemplatelog12017.txt (33.8 KB)
vantagelog.txt (123 KB)
the export routine uses the data file for the solar data and not the vantagelog
but you could try converting the vantagelog to solar data file
via action, convert WD logfiles to data files (convert solar log to solar graph)
Block Update - Weather Facts 2.0
Hi guys,
added:
- Australia
- New Zealand
Enjoy
