Meteotemplate - new free website template
Hi guys
[color=red][b]Block Update
[color=red][b]New Block
It’s no great drama, J
[quote author=Dujon link=topic=60996.msg524248#msg524248 date=1498100289]
Righteo, J
No problem, I know it is sometimes confusing when there is a block and similar plugin, the plugins are always sort of more detailed and blocks are more like “partial plugins” which can fit in a small space and summarize the most important thing, in this case the sea temp.
[color=red][b]New Plugin
[color=red][b]Plugin Update
Hi guys,
[color=red][b]READ THIS PLEASE:
http://meteotemplate.com/blog/?p=2884[/b][/color]
OK, based on two access logs I have seen, this looks like someone guessed the password, re-created the cookie and that logged them in straight because from the access logs I can see they were immediately logged in, the template would ask for password or redirect to login page, but there is no try of that, as a fix for now, i removed the cookie feature, you can dwonload updated header.php, which for now should prevent anyone misusing the cookie. Also then log out of your template and for now you will not be able to use the Remember me feature if you update the new header.
[color=red][b]Jun 29, 2017
