[color=red][b]New Plugin
Hi.
Regarding the webcam plugin, it say
Meteotemplate 13.0 Lemon
Hi guys,
as mentioned in a previous post, this is a very minor update, I only needed to add some things to the index file, which will greatly increase potential for new blocks / block improvements. I have also fixed one minor bug in one of the pages.
I am primarily now working on version 14, which should be ready probably in a few weeks. I started working on version 12 in December, and I only wanted this to be about the api, which was problematic and required co-ordination and synchronization with other developers. I have started working on version 14 in January after your suggestions from the questionnaire. However I decided to release this one extra update with just the very few files because of the potential it will bring.
[b]The update should take you maybe 10 seconds
[quote author=tobydude link=topic=60996.msg520865#msg520865 date=1490260372]
Hi.
Ok. My photos are not saved to the same server that Meteotemlape is on.
The webcam block works fine. Here: [url=http://fj
then this could be the issue because in the block, the image is loaded by the browser, in the plugin, it is loaded by the server and if your server has some configuration that does not allow loading external sources like this, then this is a problem.
[color=red][b]Block Update
Ok. Thank you.
Hi guys,
just like there is lots of blocks there is also lots of languages now, so again to make it easier and better adapted to the current situation, I [b]added a new link in the Translations section
Hi guys,
[color=red][b]New Block
[quote author=Jachym link=topic=60996.msg520912#msg520912 date=1490364239]
I wonder how your updates are working because the api realtime file is not on your server and this should be created everytime you run the api.php
nice work re dynamic graph
Hi guys
Hi. I wonder myself…
i
The APi is simple, you set it up in WD, provide URL of api.php and update interval. And then make sure you disable all other CRON jobs you had for meteotemplate, they must be disabled if you use the api. It bypasses clientraw, that file is not used by MT any more
Hi, Yes I understand the consept. Very smart, and handy.
I understand tou have given it a lot of thinking how to make things easy. Thats great.
I guess it
