wxsimate has reverted back to ATL+72219, also file to create is now c:\wxbig'data.txt
It should be CXY+72517 and c:\wxsim\w’data.txt
Noticed last night hadn’t downloaded in 24 hours. Caused many unhandled exception errors:
************* Exception Text **************
System.IO.DirectoryNotFoundException: Could not find a part of the path ‘c:\wxbig'data.txt’
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, I
System had been up and running for 31 days
Not sure what setting I should fix, in which program
It sounds like your custinit.txt file went missing. WxSim creates a Custinitbak.txt file that may still be good so you could rename it. Otherwise, hopefully you kept a copy of the one Tom provided in your original customization. Tom can provide a new one if necessary.
Jim,
My custinit.txt file looks ok.
It appears the program unregistered itself? I put the reg code in and restarted prg and my site reappeared CXY+72517
The other custom setting are gone also, weather program, paths, etc.
I changed backed quickly, have to go to work. Did download & import, looks ok.
I’ll see if I missed anything later…
Let me know if you are still having any problems.
Tom
Tom,
Only wxsimate was affected, I had to re-enter file paths, download dir info, and schedule.
I think its back to normal AFAIK.
I have backups, would it have been easier to restore a specific file?
Hi Ed,
The file is wxsmini.txt. Just be sure it’s not saying the site is ATL (upper left text box).
Tom
I had the exact same thing happen,
just want to thanks for the posts, they got mine sorted quickly.
Stephen
