I have just had to restart my machine running Lite and on start up none of the check boxes are ticked for DST, Use Initial, Use Correcttions or Forecast. I would have expected these to be remembered at start up or are they maybe set on scheduled download? All 4 boxes were ticked when I hit exit prior to restarting the PC.
Hi Stuart,
All these boxes can be checked (or unchecked) manually to force certain actions. However, they automatically check or uncheck themselves as needed while the program is doing automated tasks. You can actually watch them change as needed. For example, the DST box will change as the date being analyzed crosses the start or end dates of DST in spring or fall (those dates being something you enter, and those ARE saved). In other words, I believe everything is fine.
Tom
Thanks Tom, I was just not sure if they needed checking each restart or not and now I know
