I have been trying to get a “stationless” version running by collecting the client raw.txt data over the internet. Most of the data is being received successfully with one notable exception. The temperature is fixed on 13C while the Windchill is giving the exact temperature albeit x10. Please see attachment. The actual temperature is 20.1C. I know a stationless version is not a priority but just wondered if I have something set-up wrongly.
My Mac stationless set-up is using data from my Weather Underground site. How do I set my system up to use the clientraw.txt generated by my Windows version? Is this possible?
you do that via the client/server setup in the FTP/internet setup
where you set the location for the clientraw.txt file (e,g on a shared drive (samba?)
but why not move fully to the Mac version now with the latest update? (now build 230)
I will do eventually Brian, but I’m away on holiday shortly and I know my current Windows set-up is reasonably stable. I can also control Windows in Parallels remotely, in case there is a problem.
When I’m back from holiday, and I can monitor my system from home, I’ll consider switching and get rid of the dreaded Windows forever.
