Have you tried looking in the ftpwdisplay.ini (think that’s what it’s called) to check that everything is ok in their? I had similar problems a while back with FTP uploads and there was an issue with some of the FTP upload details in that file…
Deputydewarg had this problem
the wdisplayftp.ini file was getting corrupted on WD start up
copying a back up of that after WD has started up I think was the solution…try that
It shows this:
Loaded all time records
Loaded units
Asking for archived data download
TCP/IP connected to 192.168.1.61
re starting download, timer
sending DMPAFT
Davis VP Retrieving data from: day 6 month 10 year 2015
Retrieving data from: hour 19 minute 44
ask for time/date of record… #2Command not understood, restarting
sending DMPAFT
Sending OK…
Aborted
All data downloaded or did not sync correct!
formating the VP data
vp data read in 1
Weather station type number 31
VP reception #1 27615 #2 177 = 99
VP reception #1 27636 #2 177 = 99
VP reception #1 27659 #2 177 = 99
Hi Brian WD MacB250 Version on 4 October 2015 - 23:42:35 shut down @ noon today. Had to restart WD all seems fine.
There was nothing in program error log.
sending DMPAFT
that is the clue there…the response back is not what was expected
I have tested a number of times and it works here
but I will add some debug code to see what data is being returned on your setup @bdtripps
it would be interesting to know if the problem is the FWI (i.e try turning the updates that off as a test)
@doggy
did you find a backup of the wdisplayftp.ini file?
does the ftp settings show up OK in WD itself?
one thing I could do is to get the cronftp to use a different ftp ini file (i.e a copy…creatd before WD uses it)
Loaded units
sending DMPAFT
Davis VP Retrieving data from: day 7 month 10 year 2015
Retrieving data from: hour 15 minute 15
0 89 119 233 2 47 106 2
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
sending DMPAFT
0 9 14 2 12 7 10 13
sending DMPAFT
0 1 0 0 0 118 180 10
sending DMPAFT
Sending OK…
Aborted
vp data read in 1
VP reception #1 12948 #2 65 = 100
it is strange that it is working OK here every time
but for you, the data logger is not sending back what is expected
(there should be a 6 in that raw data (6 means OK response)
what I could do is add in some more debug code
