Hi folks, got a new one, error 5 in wxmain, i cant even find a wxmain and theres nothing showing
in the search with regards to this
I hve even tried deleting all the last*** files but that didnt help
WRET is also unusable , see other error attached
I did do the latest updates to windows prior to these errors…
no changes and new installations in my WIN7, but tonight first time getting ERROR 6, after clicking OK, getting ERROR 5 (cannot close, just using the task manager…
Yep, looks like an issue with something in the downloads at the moment.
I’ve just re-downloaded the WXSimate data but changed from using GFS from Bohlar to downloading from Chris and WXSim ran fine, yet I also saw Error 5 & Error 6 in wxmain on my 1800 forecast run.
I can’t say there is anything wrong with the Bohlar data, but that’s all I changed.
Yes, happening here too - both error 6 and error 5 in wxmain were popping up. Luckily I was sitting at the computer and watching at the time the auto run was going and spotted it - on the bit of the output screen that was completed, I saw that forecast temperatures were going extremely high like 193
[quote author=DerekH link=topic=60667.msg483788#msg483788 date=1433358079]
Mine still not working after changing wxsimate to McMahon.
Same crash. Tried to delete some data but problem remains.
Deleted also wxsimlite fiile which is corrupt. No solution.
I found my WXSIM caught in an error 5 dialog (repeating), so thanks to the above suggestion, just switched from Bohler to McMahon for GFS on WXSIMATE, did a download and local, then WXSIM ran fine with no errors…
Unfortunately, I tried using the download from Chris’ site, but WxSim still gives me the error 5. I compared wdata.txt after a McMahon download with wdata.txt after a Bohler download that they were exactly the same. So, I’m at a loss as to what’s causing the error.
I could not find the file which caused the error.
So I replaced a backup from wxsim from 6 p.m. today. At that time the wxsim run worked well.
So now it is working again after changing Bohler to McMahon.
Always good to backup every day.
Tom, I have all files from my wxsim version which crashed. May be you want some files to investigate what is wrong?
