Hi, does anyone know if the Array Elements in the clientraw.txt is always 175? Does it change?
There are older versions of WD which made/make smaller clientraw.txt files. The version of the WD program can be checked as the last item of the clientraw array contains a program version type of coding: !!C10.37R41!! or !!C10.37R81!!
As far as I know newer fields were always inserted at the end of the files just before the program version coding.
This one !!C10.37Of!! is missing the 6 “current cost channel” items and 1 “windrun” item, total length 167 items.
Excellent thanks.
the file
clientrawdescription.txt
is updated when every more data is added
