I am attemting to install WDisplay in a Centos 5 linux environment. I have installed the GTK package. However, when running the GoWeather.sh script the following error messages are generated:
root@mars wdisplay]# ./GoWeather.sh
[HINT] TWinControl.CreateWnd creating Handle during loading MainForm:TMainForm csDesigning=False
(WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion GDK_IS_DRAWABLE (drawable)' failed (WeatherD:1398): GLib-GObject-WARNING **: gsignal.c:1667: signal
button-press-event’ is invalid for instance 0xf8057a0' (WeatherD:1398): GLib-GObject-WARNING **: gsignal.c:1667: signal
button-release-event’ is invalid for instance 0xf8057a0' Form resource TFormtimer1 not found. For resourceless forms CreateNew constructor must be used. See the global variable RequireDerivedFormResource. (WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion
GDK_IS_DRAWABLE (drawable)’ failed
(WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion GDK_IS_DRAWABLE (drawable)' failed (WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion
[HINT] TWinControl.CreateWnd creating Handle during loading Formtempdials:TFormtempdials csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading weatherdials:Tweatherdials csDesigning=False
(WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion GDK_IS_DRAWABLE (drawable)' failed [HINT] TWinControl.CreateWnd creating Handle during loading Formpercentdir:TFormpercentdir csDesigning=False (WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion
THE ABOVE LINE REPEATED MANY TIMES
[HINT] TWinControl.CreateWnd creating Handle during loading averages:Taverages csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading PageControl1:TPageControl csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading TabSheet1:TTabSheet csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Splitter1:TSplitter csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button5:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button6:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading ProgressBar1:TProgressBar csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button1:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button4:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading BitBtn1:TBitBtn csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading printpage:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button8:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button9:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading GroupBox5:TGroupBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEditday:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEditmonthsel:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEdityearsel:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button14:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button26:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button3:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading GroupBox8:TGroupBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading CheckBoxsoil:TCheckBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEditgdd:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading CheckBoxusemydatarecords:TCheckBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEditheatdegrees:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEditheatdegrees2:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading logmemo2:TMemo csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading logmemo:TMemo csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading TabSheet2:TTabSheet csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button23:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading BitBtn2:TBitBtn csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading ProgressBar3:TProgressBar csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button21:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading GroupBox6:TGroupBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEdit2:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading SpinEdit3:TSpinEdit csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button16:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Button30:TButton csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading CheckBoxmaxminaverage:TCheckBox csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading Memonoaa:TMemo csDesigning=False
[HINT] TWinControl.CreateWnd creating Handle during loading TabSheet3:TTabSheet csDesigning=False
(WeatherD:1398): Gdk-CRITICAL **: gdk_drawable_get_size: assertion `GDK_IS_DRAWABLE (drawable)’ failed
Please could anyone suggest what is causing the above “failed” messages. Presumably it is a GTK missing dependency?
David Anderson
Loughborough - UK
