Before the forum crash, this discusion was going on about the WM-918 and ConsoleWD. The last point was about the option to use a SYMLINK for devicenames. So not using /dev/ttyUSB0 (or like in the configfile only COM=N), but that /dev/Weather-USB or any other name that was dfined by using UDEV naming.
In the meantime I’ve been testing with the Console 12.1 version that was made as test to solve the DAILY-RAIN problem. it looked like it was working fine, but the last 2 days we are having rain, but something very strange is going on. If you have a look at WUNDERGROUND by my station, then you see a graph (and also in the TABEL) were 1 moment the “Precip. Accum” is 0 mm and a few minutes later it is 3 mm. (date April 29 and 30). http://www.wunderground.com/personal-weather-station/dashboard?ID=INHAMSTE6#history
So I did some debugging. If I have a look in the output that is displayed on the screen by CONSOLWD, then everything looks fine. But if I have a look in what is been put in the CROMWUDATA.TXT then something is wrong:
root@raspberrypi:/home/pi/w-disp/consolewdfiles# cat cronwudata.txt
http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=10&action=updateraw&ID=INHAMSTE6&PASSWORD=xxxxxx&dateutc=2015-04-30+21%3A22%3A23&winddir=232&windspeedmph=6&windgustmph=5&humidity=62&tempf=45.5&rainin=0.00&baromin=29.884&dewptf=33.2&weather=&clouds=&dailyrainin=[b]0.00[/b]&softwaretype=WeatherDisplay%3AWD_console_12.1
http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=10&action=updateraw&ID=INHAMSTE6&PASSWORD=xxxxxx&dateutc=2015-04-30+21%3A22%3A28&winddir=219&windspeedmph=3&windgustmph=4&humidity=63&tempf=45.3&rainin=0.00&baromin=29.884&dewptf=33.5&weather=&clouds=&dailyrainin=[b]0.12[/b]&softwaretype=WeatherDisplay%3AWD_console_12.1
http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=10&action=updateraw&ID=INHAMSTE6&PASSWORD=xxxxx&dateutc=2015-04-30+21%3A22%3A28&winddir=232&windspeedmph=6&windgustmph=5&humidity=62&tempf=45.5&rainin=0.00&baromin=29.884&dewptf=33.2&weather=&clouds=&dailyrainin=[b]0.00[/b]&softwaretype=WeatherDisplay%3AWD_console_12.1
But in my NOHUP file, then I see for the same date and time record:
So looks like that the CROMWU task is messing up some data. Is that possible?
