Help needed..total Noobe Linux user cant get WD to work
Hi…I am trying to get WD to run under Ubuntu as a guest OS using VirtualBox (Windows 7 Ultimate is the host OS). I am hoping to get WD up and running using a RasberryPi or some other plug computer, but first I wanted to familiarize myself with Linux. I have followed the instructions I can find as far as checking the serial port and the like, but when I run the “./GoWeather.sh” command, the initial WD window starts up, then freezes saying “Loading Extra Sensors Graph…”, then turns gray. On the terminal window I get the following cryptic (for me, at least) message;
“[HINT] TWinControl.CreateWnd creating Handle during loading MainForm:TMainForm csDesigning=False
Form resource TFormtimer1 not found. For resourceless forms CreateNew constructor must be used. See the global variable RequireDerivedFormResource.”
I didn’t find this much of a “hint” LOL
I have my station which is a Peet Bros 2100 up and running fine under Windows using Virtual Weather Station.
any ideas or help would be appreciated. Thanks, Steve N2QLQ
there are other threads about this…
other distros will work better other than Ubuntu 12
(Ubuntu 11 even)
consolewd will work OK
on linux or a raspberrypi
