Steel Gauges with Raspberry Pi?
Hi guys
Can the Raspberry Pi version create the customclientraw.txt needed for Steel Gauges please as I’m hoping to put this in for new clients?
Many thanks
John
yes it can
set that in the config.txt
and have the customclientrawlocal.txt in place as well
hello weather freaks
I got Steelseries Gauges running on my Pi. Everything is working fine except the wind rose and the rain rate gauge.
Customclientraw.txt fields are empty for these parameters:
“rfall”:“5.3”,“rrate”:“0.0”,“rrateTM”:“0.0”
“WindRoseData”:[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0]
Did I miss something in the settings?
I am not sure if I added those to the raspberry pi version of consolewd
are you using the latest version of that?
(i.e which version are you using?)
I am using the one from February.
Information from clientraw.txt is: CWD_console_12.0
you should be using the latest version for starters :wink:
I updated to what I guess would be the latest version.
clientraw.txt says:
CWD_console_12.3
… but still customclientraw.txt is:
“WindRoseData”:[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0],“windrun”:“0.00” (same for rain data)
I will check up to see if I have that code added correctly, as spare time permits
hello Brian … did you got some spare time to check for my issue?
the code is there…in checking…and its the same code as the windows version
it should be providing results other than zero
does anyone else have this working correct?
This one from the downloads section?
“Weather Display for Linux console version for raspberry pi Version on 4 May 2015 - 04:16:16”
Mine appears to be working ok.
http://whitmoreweather.dx.am/SteelGauges/web_server/gauges-ss-basic.htm
I’ve done nothing more than make it work at this stage, maybe one day I’ll learn how to modify it to look a bit nicer.
Hi George,
may I ask you about your datasource i.e. weather station? I am using datain38.ini to feed directly into consoleWD on a Raspberry Pi.
Hi UW - Sorry for the delay, I only just noticed that there was a reply in this thread.
I’m using a WS1080 connected via USB to my Raspberry Pi. Although, in the post today has arrived my new WS3083 with UV and solar, so hopefully I will be getting that up and running over the next few days.
I still have the problem that windrose data is not generated by consolewd. I am using the Weather station type=34 input (universal). The datain38.ini input (0 0.00 5.4 82 953 249.275 160 0.0 24.6 43 211)
These are two customclientraw.txt readings from different times:
{"date":"18:19:20","dateFormat":"d/m/y","temp":"8.3","tempTL":"2.1","tempTH":"11.2","intemp":"24.6","dew":"2.7","dewpointTL":"1.1","dewpointTH":"5.5","apptemp":"7.4","apptempTL":"6.4","apptempTH":"6.4","wchill":"8.3","wchillTL":"2.1","heatindex":"8.3","heatindexTH":"11.2","humidex":"6.9","wlatest":"0.0","wspeed":"0.0","wgust":"0.0","wgustTM":"15.7","bearing":"0","avgbearing":"32","press":"952.0","pressTL":"952.0","pressTH":"955.0","pressL":"949.0","pressH":"955.0","rfall":"8.6","rrate":"0.0","rrateTM":"600.0","hum":"68","humTL":"55","humTH":"96","inhum":"42","inhumTL":"%minindoorhum%","inhumTH":"%maxindoorhum%","intempTL":"24.5","TintempTL":"%minindoortempt%","intempTH":"24.9","TintempTH":"%maxindoortempt%","SensorContactLost":"0","forecast":"---","tempunit":"C","windunit":"kmh","pressunit":"hPa","rainunit":"mm","temptrend":"-0.3","TtempTL":"06:35","TtempTH":"15:30","TdewpointTL":"06:35","TdewpointTH":"13:15","TapptempTL":"13:05","TapptempTH":"13:05","TwchillTL":"06:35","TheatindexTH":"15:30","TrrateTM":"04:15","ThourlyrainTH":"","LastRainTipISO":"------","hourlyrainTH":"0.0","ThumTL":"15:15","ThumTH":"08:05","TinhumTL":"%dailylowindoorhumtime%","TinhumTH":"%dailyhighindoorhumtime%","TpressTL":"05:25","TpressTH":"00:00","presstrendval":"0.0","Tbeaufort":"3","TwgustTM":"15:35","windTM":"0.0","bearingTM":"0","timeUTC":"2019,04,28,16,19,20","BearingRangeFrom10":"360","BearingRangeTo10":"130","UV":"0.0","UVTH":"0.0","SolarRad":"211","CurrentSolarMax":"0","SolarTM":"250","domwinddir":"Southeasterly","WindRoseData":[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0],"windrun":"0.00","cloudbasevalue":"699","cloudbaseunit":"m","version":"WD_console_17.5","build":"---","ver":"14"}
{"date":"21:40:32","dateFormat":"d/m/y","temp":"5.4","tempTL":"2.1","tempTH":"11.2","intemp":"24.6","dew":"2.6","dewpointTL":"1.1","dewpointTH":"5.5","apptemp":"4.4","apptempTL":"6.4","apptempTH":"6.4","wchill":"5.4","wchillTL":"2.1","heatindex":"5.4","heatindexTH":"11.2","humidex":"3.9","wlatest":"0.0","wspeed":"0.0","wgust":"0.0","wgustTM":"15.7","bearing":"195","avgbearing":"202","press":"953.0","pressTL":"952.0","pressTH":"955.0","pressL":"949.0","pressH":"955.0","rfall":"8.6","rrate":"0.0","rrateTM":"600.0","hum":"82","humTL":"55","humTH":"96","inhum":"43","inhumTL":"%minindoorhum%","inhumTH":"%maxindoorhum%","intempTL":"24.5","TintempTL":"%minindoortempt%","intempTH":"24.9","TintempTH":"%maxindoortempt%","SensorContactLost":"0","forecast":"---","tempunit":"C","windunit":"kmh","pressunit":"hPa","rainunit":"mm","temptrend":"-0.4","TtempTL":"06:35","TtempTH":"15:30","TdewpointTL":"06:35","TdewpointTH":"13:15","TapptempTL":"13:05","TapptempTH":"13:05","TwchillTL":"06:35","TheatindexTH":"15:30","TrrateTM":"04:15","ThourlyrainTH":"","LastRainTipISO":"------","hourlyrainTH":"0.0","ThumTL":"15:15","ThumTH":"08:05","TinhumTL":"%dailylowindoorhumtime%","TinhumTH":"%dailyhighindoorhumtime%","TpressTL":"05:25","TpressTH":"00:00","presstrendval":"+1.0","Tbeaufort":"3","TwgustTM":"15:35","windTM":"0.0","bearingTM":"195","timeUTC":"2019,04,28,19,40,32","BearingRangeFrom10":"95","BearingRangeTo10":"225","UV":"0.0","UVTH":"0.0","SolarRad":"211","CurrentSolarMax":"0","SolarTM":"250","domwinddir":"Southeasterly","WindRoseData":[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0],"windrun":"0.00","cloudbasevalue":"355","cloudbaseunit":"m","version":"WD_console_17.5","build":"---","ver":"14"}
As one can see the WindRoseData keeps being empty. Is there some setting I have missed?
what hardware version? (1 2 or 3?)
ConsoleWD is running on a Synology DS216+II which has a X86_64 bit chip.
that really does not answer my Q very well
which version of consolewd are you using?
The information from clientraw.txt is: CWD_console_17.5
Yes
But
Did u download the version for raspberry pi
1/2 or 3 or for Linux?
