Weather Display stop on splash "Loading extra sensors graph"
Hi.
I have WMR200 and linux mint (32 bit) on my pc (In ubuntu, xubutu 12.xx this problem present to).
When i start program:
sudo ./WeatherD
[HINT] TWinControl.CreateWnd creating Handle during loading MainForm:TMainForm csDesigning=False
and open splash screen with “Loading extra sensors graph” and the program hangs
How i fix this problem?
PS: I tried Ubuntu 12.10/64, 12.04/32, LMDE 64, Mint 16/32 - everywhere identical problem
PPS: In Ubintu 11.04 all worked, but I want new distribution kit :frowning:
I think the solution is I need to udpate the compiler and re compile
I will try that soon and let you know
I will wait very much. thanks 8)
So…
I download new version (Version on 3 January 2014 - 20:31:17) of WD GUI for linux.
Now ‘splashv’ stop on:
wdisplay # ./WeatherD [HINT] TWinControl.CreateWnd creating Handle during loading MainForm:TMainForm csDesigning=False Form resource TFormtimer1 not found. For resourceless forms CreateNew constructor must be used. See the global variable RequireDerivedFormResource.
the update I have done was in relation to another thread (missing menus in Ubuntu 11)
I tried to update the compiler but my distro is not compatible
So I will need to install Ubuntu 12 by the looks
I will have to get a copy of that for starters
