HOWTO: ConsoleWD for Raspberry Pi Setup Instructions - Old version
there must have been a change to the usb/hid library
great that it ran for 2 years (was that non stop, or?)
re more info, I would need to get a new version up for you…with more raw data…
yes it run 2 years non-stop, i have another one here too: https://www.wunderground.com/personal-weather-station/dashboard?ID=ICANTONO10
exactly same raspberry pi 2 and irox pro 2.
Luckily i did not upgrade this PI.
The one I upgraded is located in a remote place, so I can not visit it easily, so I am hoping you will find a solution.
I just did the libhid and libusb compile on this upgraded raspbian OS but exactly the same behaviour. No data apart of that unreal barometer reading:
~/consolewdfiles $ sudo ./consolewd
Station type raw=59<
Station type =59
Weather station type is an Irox
Davis com method d
OWW file location= ←
program location= /home/pi/consolewdfiles/<-
Davis VP IP data logger port= 22222<
Davis VP IP data logger IP= 192.168.2.3<-
Station name =My station
Daily rain startup= 0.0
Monthly rain startup= 0.0
wunderground username =
wunderground password =
wunderground utc =-5
Dir offset= 0
Barooffset= 0.0
Comport is USB to serial
Davis com method d
Yes Revb Davis VP
Davis rain gauge .01 inch
mysql username =
mysql server =
mysql databasename =
mysql tablename =
Will do mysql metric
mysql time interval = 300
cwop station id =
cwop call sign = -1 // -1 is default (you do not have a Ham call si
cwop latitude=
cwop longitude=
FTP server =
FTP username =
FTP port = 21
FTPremote dir =
Will do ftp passive
remote file =
FTP time interval = 60
wu =Y
Will save logfile
logfile metric
Custom file name = wx.html
Custom file name 2=
Custom file name 3=
Custom file name 4=
Custom file name 5=
Tag units in celsius
wind units = kts
baro metric= Y
rain metric= Y
Will run cron files
Custom log out = customlogout.txt
temp offset raw = <
wmr300 channel =1
utc hour=18
local hour=20
Weather Display vers WD_console_12.3
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
www.weather-display.com
Irox opened OK
irox write 5
irox read -1
irox read -1
irox read 34
Raw irox baro 4095.9
irox read -1
irox read -1
I have a Raspberry pi 3 here now…64 bit…
and so that probably has the updated OS
I will test with my Irox station…
thank you, lets see.
I have tested consolewd 64 bit version on my raspberry pi, 3 which is a recent version
4.1.18
and it works with my Irox station OK
I wonder if the problem you have is related to the raw barometer being out of range
I could try updating my OS to 4.1.19
but have you tried re compiling libhid , as per the original setup?
I am running: root@raspberrypi:~# uname -a
Linux raspberrypi 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
and its an older PI 2 only.
I recompiled both libhid and libusb following the instruction shown on the first page of this post. It did not help.
Back in 2 years ago, I did not compile the libhid and libusb, as I recall, you shared these and i just downloaded from your site that time, but never compiled then. i just tried to recompile only now.
I could try updating my OS…how do I do that?
ps, this should really be in its own thread?
as root, just run
apt-get update
apt-get upgrade
done that…
it went through the process
I even rebooted
but its still 4.1.18
and consolewd still works
maybe the 64 bit OS has not been updated?
I could try updating my raspberry pi 1
yes, it can be that the 64 bit variant is running a bit behind or like with some other linux distros, maybe some application is preventing you to upgrade it.
OK lets see with the older one.
I got my Raspberry pi 1 updated to 4.1.19
March 15th
consolewd is still working OK for my Irox station
(e.g the barometer data returned is OK)
the data received number you are getting is OK… (34)
but what I can do is add in to show the raw data received
it could be that the barometer reading is out of range?
let me know what the raw data shows for this test version
http://www.weather-display.com/downloadfiles/consolewdiroxtest.zip
thanks for the troubleshooting, with your test version i see these:
Irox opened OK
irox write 5
irox read -1
irox read -1
irox read 34
5A 1
02 2
83 3
49 4
95 5
C2 6
50 7
0A 8
00 9
0A 10
0A 11
00 12
0A 13
0A 14
00 15
0A 16
0A 17
00 18
0A 19
FF 20
FF 21
FF 22
FF 23
05 24
FF 25
FF 26
FF 27
FF 28
FF 29
FF 30
E0 31
41 32
0B 33
3A 34
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox write 5
irox read 34
5A 1
02 2
83 3
49 4
95 5
C2 6
50 7
0A 8
00 9
0A 10
0A 11
00 12
0A 13
0A 14
00 15
0A 16
0A 17
00 18
0A 19
FF 20
FF 21
FF 22
FF 23
05 24
FF 25
FF 26
FF 27
FF 28
FF 29
FF 30
E0 31
41 32
0B 33
3A 34
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox write 5
irox read 34
5A 1
02 2
83 3
49 4
95 5
C2 6
50 7
0A 8
00 9
0A 10
0A 11
00 12
0A 13
0A 14
00 15
0A 16
0A 17
00 18
0A 19
FF 20
FF 21
FF 22
FF 23
05 24
FF 25
FF 26
FF 27
FF 28
FF 29
FF 30
E0 31
41 32
0B 33
3A 34
^Cpi@raspberrypi ~/consolewdfiles $
any idea why i dont have anything in this file?
pi@raspberrypi ~/consolewdfiles $ pwd
pi@raspberrypi ~/consolewdfiles $ ls -la clientraw.txt
-rwxrwxrwx 1 pi pi 0 Jul 9 09:55 clientraw.txt
please note that unit dont have the water / wind sensor unit connected(battery died some month ago). Only the outside temp sensor unit is connected via wireless link.
OK, the data is synced OK, the 5A at the start is what is to be expected
the barometer data is this data:
FF 22
FF 23
which are both NULL 255
which points to a hardware issue with the barometer (its basicly out of range/not working or similar)
and because of that , the program is ignoring all the other data
(I could make this special version carry on so you at least get outdoor/indoor temperature?
download again, …same URL…
so that it will carry on and ignore that NULL barometer values
Brian, you are a BIG BIG Magican !! :smiley:
irox write 5
irox read 34
Raw irox baro 4095.9 FF FF
irox Data OK
Current data : Temperature= 30.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=52 Barometer=1013.0 Daily Rain=0.0
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox write 5
irox read 34
irox Data OK
irox read -1
irox read -1
and now I have data:
pi@raspberrypi ~/consolewdfiles $ cat clientraw.txt
12345 0.0 0.0 0 30.1 52 1013.0 0.0 0.0 0.0 0.000 0.000 30.8 50 0.0 0 0.0 0 0 0.0 -1.0 -1.0 -1.0 -1.0 166.5 0.0 10 10 10 13 04 49 My_station-13:04:49 0 0 9 7 0 0 0 0 0 0 0 30.1 37.0 30.1 30.1 0 Dry 0.0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0.0 19.2 4506.6 9/7/2016 37.0 37.0 30.1 30.1 0.0 0 0 0 0 0 0 0 0 0 0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 23.3 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 31.5 31.5 31.5 0.0 0 — — 0 0 0 0.0 0.0 10 165 0 0 0 0.0 30.8 30.8 33.0 1013.0 1013.0 0 00:00:00 00:00:00 33.0 33.0 19.2 19.2 0 2016 2016 1 1 -1 0 0 0 0 0 0 0 0 0 0 0.0 0.0 0.0 22.9 0.0 0.0 0.0 52 52 !!CWD_console_12.3!!
OK, I thank you million times, and now we all know that if some of the data is missing because of disconnected units or faulty sensors we have such issue. Actually now I will use this test variant, as I really like this way, if i lose connection to some of the wireless sensors, I will still have data to monitor.
Great job Sir!
donations gladly accepted :wink:
Hi Bryan
I have tried to install
At page 1 you can try this, maybe it helps!
errors which may pop up Missing libhid.so.0 In the deploy folder simply copy libhid.so.0.0 to libhid.so.0 and do step 2.4 again
At least this list (got it from Raspi), tested it a few times for writing an instruction in Dutch, works for me.
Staccermaccer,
Anyone interested can download an image for the Raspberry PI with consolewd preinstalled. Tested with Irox station type.
https://www.dropbox.com/s/x4ryw78637hm99i/rpi_consolewd.gz?dl=0
md5sum: 2463de4fd0b77a2268546761cf2b107a
Image shall fit onto 8 GB SD card (this is where I created it from) but I suggest to use a 16 GB instead. Username/pass are RPi default (pi/raspberry). SSH is enabled.
All consolewd parameters are left default.
