Perfect, thanks.
or… maybe even better (to help reduce the number of read/write on the SD-card), if you could specify the path in which to create the original clientraw.txt file… is there a setting for that in config.txt ?
or… can you create a symbolic link in the /var/www/weather28/uploadCW/ that points to the /home/pi/consolewdfiles/clientraw.txt ?
/Niklas (Linux NOOB)
