cloudy
Author Topic: ConsoleWD for Raspberry Pi Setup Instructions  (Read 11879 times)
Offline wvdkuil
  • Wim van der Kuil
  • Amsterdam / Netherlands
  • Mac OS X 10.9.5
  • Chrome 42.0.2311.90
    • Weatherstation Wilsele/Leuven/Belgium
Re: ConsoleWD for Raspberry Pi Setup Instructions
« Reply #15 on: April 29, 2015, 11:55:24 AM »
2015-April 29:
There is also a image available for use with the first raspberry B and the B+  So not (yet) for the 2.
The pdf is at: http://www.weerstation-leuven.be/CW-image-install-english.pdf
In the pdf is the download link.
md5 in the pdf is not updated
The download versions name = 2 but contains the latest (4) version.  Although that is not important because those discussions are lost forever.
Meteohub / Meteobridge with Vantage Pro2+
www.weerstation-wilsele.be   and   www.weerstation-leuven.be
WeatherDisplay Cumulus Weatherlink using VVP and WeatherCat on a Mac Mini for development
consoleWD on a raspberry PI
Offline UW
  • Win NT 6.3
  • Chrome 43.0.2357.65
« Reply #16 on: May 22, 2015, 06:33:43 AM »
What would be the procedure to update to the latest version?
Maybe this could be added to the FAQ.
Have a nice day
Urs
Offline _Niklas_
  • Sweden, Europe
    • niklasb_78
  • Mac OS X 10.10.5
  • Safari 8.0.8
    • Lindhaga Weather, Sweden
« Reply #17 on: September 24, 2015, 09:31:37 PM »
I plan on running my own web server on my RPi.
How would I go about configuring the config.txt ?  since I don't want to FTP the clientraw to a server, instead just copying from /home/pi/consolewdfiles/clientraw.txt to /var/www/weather28/uploadCW/  (when using Leuven-Template 2.8 for example)
Ive seen config.txt with this text, will that work? :
copy clientraw/customclient raw to this directory=/var/www/weather28/uploadCW/
copy datafiles to this directory=
copy logfiles to this directory=
/Niklas
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 45.0.2454.99
    • Weather Display
« Reply #18 on: September 24, 2015, 09:54:55 PM »
that should work, yes
Offline _Niklas_
  • Sweden, Europe
    • niklasb_78
  • Mac OS X 10.10.5
  • Safari 8.0.8
« Reply #19 on: September 25, 2015, 05:20:36 AM »
Perfect, thanks.
or.. maybe even better (to help reduce the number of read/write on the SD-card), if you could specify the path in which to create the original clientraw.txt file..  is there a setting for that in config.txt ?
or.. can you create a symbolic link in the /var/www/weather28/uploadCW/ that points to the /home/pi/consolewdfiles/clientraw.txt ?
/Niklas (Linux NOOB)
Offline aharrold
  • Android 5.1
  • Chrome 48.0.2564.95
« Reply #20 on: February 02, 2016, 06:08:19 PM »
When buying a RPi do you need to install any specific Linux software on it firstfirst? If so what's recommended?
Once (should be if) I get it up and running at home is it possible to view the data on my iPad?
Complete novice on Linux and RPi.
Offline rkoradio
  • Win 7/Srvr 2008R2
  • Firefox 43.0
« Reply #21 on: February 09, 2016, 03:49:34 PM »
I have been trying to get consolewd working on my RPi 2, but no luck.  I have followed the instructions given by Wim back in 2013 to the letter.  When I try to execute the command ./consolewd, I get an error message saying that it can't find the command anywhere.  I am running the latest version of Raspian on my Pi 2.  Can anyone suggest where I might be going wrong?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 50.0.2661.102
    • Weather Display
« Reply #22 on: June 02, 2016, 12:11:54 AM »
@rkoradio
that error is because that version of the raspberry pi is 64 bit
but consolewd is only 64 bit
I now have a rasperry pi 3
nice unit
I see you can not download libhid from the link provided
but I already had that
seems to go through all the hoops in compiling and installing
but I do not get any new libhid .so files
which need to be 64 bit compiled
as the error I get on running consolewd is can not open those shared hid library files
need help wvdkuil ! :)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 49.0.2623.87
    • https://www.realweatherstation.com
« Reply #23 on: June 02, 2016, 12:14:14 AM »
@rkoradio
Huh?
  • Davis VP2
  • New Zealand
  • Android 5.0.1
  • Chrome 37.0.0.0
    • Weather Display
« Reply #24 on: June 02, 2016, 02:13:40 AM »
Typo
I meant that the current version of consolewd is 32 bit
Which will not run on a 64 bit distro raspberry pi
Which I am now trying to compile
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #25 on: June 02, 2016, 02:22:58 AM »
Got it  :D
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #26 on: June 02, 2016, 03:34:28 AM »
the libhid you can download from
http://www.weather-display.com/downloadfiles/libhid-0.2.16.tar.gz
re trying to get it to compile to the needed .so files under 64 bit raspberry pi
Offline IROXproX
  • from the Land of Mountains & Banks - Switzerland
  • (Linux Mint)
  • Firefox 47.0
« Reply #27 on: July 07, 2016, 07:23:32 PM »
the "disaster" has happened after about 2 years I was brave or stupid enough to run a apt-get upgrade on the Raspberry Pi that runs the consolewd and now it doest work anymore. I could cry now.
I am getting this:
****Weather Display vers WD_console_12.3****
If use this program,then please consider sending a PayPal donation to info@weather-display.com (Brian Hamilton)
to help with costs, and support, thanks!
Irox opened OK
irox write 5
irox read 34
Raw irox baro 4095.9
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox read -1
irox write 5
irox read 34
irox read -1
and the clientraw.txt stays empty.
pi@raspberrypi ~/WX $ uname -a
Linux raspberrypi 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
this raspy is on a remote station 2000km away from me, only SSH access.
Is there any change to make it work again?
Raspberry PI 2 and IROX Pro X2.
Many thanks
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 51.0.2704.103
    • Weather Display
« Reply #28 on: July 07, 2016, 08:19:01 PM »
that looks like the data is out of sync
it might come back into sync?
re the 64 bit compile, I did get that to work now on my raspberry 3 ( there was another thread about that) ;)
Offline IROXproX
  • (Linux Mint)
  • Firefox 47.0
« Reply #29 on: July 08, 2016, 03:26:14 AM »
Brian,
i did restart the raspberry but all the time same issue, barometer is crazy reading and nothing in here
pi@raspberrypi ~/WX $ ls -la clientraw.txt
-rwxrwxrwx 1 pi pi 0 Jul  7 21:11 clientraw.txt
I can not restart the IROX as it is in remote, also I can not rewrite the SD card image to an old raspbian.
I am pretty sure the raspbian upgrade killed it.
Is there a way to make it work with the lastest raspbian? Are you aware of that issue that if someone upgrade the OS, it stops working?
Can you please make a test or what should i try to do to give you some debug info? Many thanks
w interface driver hub
[    0.601025] usbcore: registered new device driver usb
[    0.607036] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
[    0.642715] Switched to clocksource stc
[    0.696270] FS-Cache: Loaded
[    0.699593] CacheFiles: Loaded
[    0.718003] NET: Registered protocol family 2
[    0.723933] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.731124] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.737756] TCP: Hash tables configured (established 4096 bind 4096)
[    0.744400] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.750299] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.757007] NET: Registered protocol family 1
[    0.761972] RPC: Registered named UNIX socket transport module.
[    0.768023] RPC: Registered udp transport module.
[    0.772797] RPC: Registered tcp transport module.
[    0.777531] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.785245] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.794385] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.816731] VFS: Disk quotas dquot_6.6.0
[    0.821103] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.830761] FS-Cache: Netfs 'nfs' registered for caching
[    0.837533] NFS: Registering the id_resolver key type
[    0.842834] Key type id_resolver registered
[    0.847058] Key type id_legacy registered
[    0.854890] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.862881] io scheduler noop registered
[    0.866882] io scheduler deadline registered (default)
[    0.872462] io scheduler cfq registered
[    0.878861] BCM2708FB: allocated DMA memory 5b800000
[    0.884034] BCM2708FB: allocated DMA channel 0 @ f2007000
[    0.894582] Console: switching to colour frame buffer device 82x26
[    0.905847] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[    0.914741] KGDB: Registered I/O driver kgdboc
[    0.921898] vc-cma: Videocore CMA driver
[    0.927644] vc-cma: vc_cma_base      = 0x00000000
[    0.934043] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.941024] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.948308] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.978841] brd: module loaded
[    0.992655] loop: module loaded
[    0.998545] vchiq: vchiq_init_state: slot_zero = 0xdb880000, is_master = 0
[    1.009087] Loading iSCSI transport class v2.0-870.
[    1.017230] usbcore: registered new interface driver smsc95xx
[    1.024835] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.232417] Core Release: 2.80a
[    1.237195] Setting default values for core params
[    1.243578] Finished setting default values for core params
[    1.450862] Using Buffer DMA mode
[    1.455798] Periodic Transfer Interrupt Enhancement - disabled
[    1.463266] Multiprocessor Interrupt Enhancement - disabled
[    1.470415] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.476408] Dedicated Tx FIFOs mode
[    1.481861] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdb814000 dma = 0x5b814000 len=9024
[    1.494990] FIQ FSM acceleration enabled for :
[    1.494990] Non-periodic Split Transactions
[    1.494990] Periodic Split Transactions
[    1.494990] High-Speed Isochronous Endpoints
[    1.518172] dwc_otg: Microframe scheduler enabled
[    1.518301] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc03dd8e0
[    1.525881] WARN::hcd_init_fiq:413: FIQ ASM at 0xc03ddbbc length 36
[    1.533793] WARN::hcd_init_fiq:438: MPHI regs_base at 0xdc896000
[    1.541522] dwc_otg 20980000.usb: DWC OTG Controller
[    1.548186] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    1.557221] dwc_otg 20980000.usb: irq 32, io mem 0x00000000
[    1.564464] Init: Port Power? op_state=1
[    1.569935] Init: Power Port (0)
[    1.575063] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.583520] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.592330] usb usb1: Product: DWC OTG Controller
[    1.598630] usb usb1: Manufacturer: Linux 4.1.19+ dwc_otg_hcd
[    1.605970] usb usb1: SerialNumber: 20980000.usb
[    1.613264] hub 1-0:1.0: USB hub found
[    1.618704] hub 1-0:1.0: 1 port detected
[    1.624803] dwc_otg: FIQ enabled
[    1.624826] dwc_otg: NAK holdoff enabled
[    1.624841] dwc_otg: FIQ split-transaction FSM enabled
[    1.624906] Module dwc_common_port init
[    1.625450] usbcore: registered new interface driver usb-storage
[    1.633519] mousedev: PS/2 mouse device common for all mice
[    1.641688] bcm2835-cpufreq: min=700000 max=700000
[    1.648487] sdhci: Secure Digital Host Controller Interface driver
[    1.656293] sdhci: Copyright(c) Pierre Ossman
[    1.662602] sdhost: log_buf @ db813000 (5b813000)
[    1.742801] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.750460] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.778682] ledtrig-cpu: registered to indicate activity on CPUs
[    1.786646] hidraw: raw HID events driver (C) Jiri Kosina
[    1.794028] usbcore: registered new interface driver usbhid
[    1.801192] usbhid: USB HID core driver
[    1.811147] Initializing XFRM netlink socket
[    1.817471] NET: Registered protocol family 17
[    1.823783] Indeed it is in host mode hprt0 = 00021501
[    1.891814] Key type dns_resolver registered
[    1.904446] registered taskstats version 1
[    1.910544] vc-sm: Videocore shared memory driver
[    1.917154] [vc_sm_connected_init]: start
[    1.924264] [vc_sm_connected_init]: end - returning 0
[    1.933452] Waiting for root device /dev/mmcblk0p2...
[    1.950479] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.963712] mmc0: new high speed SDHC card at address b368
[    1.971669] mmcblk0: mmc0:b368 AF SD 15.1 GiB
[    1.979775]  mmcblk0: p1 p2
[    2.052833] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.062013] Indeed it is in host mode hprt0 = 00001101
[    2.131072] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.142703] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.160791] devtmpfs: mounted
[    2.166763] Freeing unused kernel memory: 348K (c0771000 - c07c8000)
[    2.283300] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.292043] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.303813] hub 1-1:1.0: USB hub found
[    2.310822] hub 1-1:1.0: 3 ports detected
[    2.592943] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.723347] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.732247] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.755540] smsc95xx v1.0.4
[    2.839184] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5c:4d:18
[    2.952891] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
[    3.088886] usb 1-1.3: New USB device found, idVendor=1130, idProduct=6801
[    3.097930] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.107233] usb 1-1.3: Product:
[    3.129487] hid-generic 0003:1130:6801.0001: hiddev0,hidraw0: USB HID v1.10 Device [ ] on usb-20980000.usb-1.3/input0
[    3.836950] udevd[156]: starting version 175
[    6.081529] bcm2835-rng 20104000.rng: hwrng registered
[    8.102840] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[   10.575039] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   10.966272] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.304855] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   19.648512] random: dd urandom read with 108 bits of entropy available
[   20.455918] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   21.956644] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x51E1
[   22.514210] random: nonblocking pool is initialized
[   30.605222] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:507900k SSFS
[   40.444090] uart-pl011 20201000.uart: no DMA platform data
[   44.463466] fuse init (API version 7.23)
[  130.526073] usb 1-1.3: usbfs: process 3112 (consolewd) did not claim interface 0 before use
[  130.526556] usb 1-1.3: usbfs: process 3112 (consolewd) did not claim interface 0 before use
[  130.526949] usb 1-1.3: usbfs: process 3112 (consolewd) did not claim interface 0 before use
root@raspberrypi:~#
root@raspberrypi:~# lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 1130:6801 Tenx Technology, Inc.
root@raspberrypi:~#
« Last Edit: July 08, 2016, 03:59:20 AM by IROXproX »
