Author Topic: Freak Weather  (Read 743 times)
Offline Dotty
  • Witham, Essex
    • Witham WX
Freak Weather
« on: October 20, 2004, 11:37:13 PM »
Hi, I don't have a problem as such here more curious than anything else. We've got some atrocious weather over here at the moment but I noticed something very odd on my graph this afternoon, that I've never had before. if you look at my graph
the windchill for a while this afternoon was actually warmer than the temperature. If I'd have downloaded a new version I'd have probably put it down to a glitch but I haven't and I really can't recall ever seeing that before. Could it be something to do with the heat index? Has anyone else ever had this happen?
Justine Coxell
Re: Freak Weather
« Reply #1 on: October 21, 2004, 12:57:00 AM »
the windchill changes to heat index (or humidex if you select that in the summary image and icon setup) when its over 17oc (that is freaky for the UK!)
but you can disable that in 10.18g (in fact it should be off by default) in the graph setup
Offline NorCal Dan
  • -= Dan =-
  • Marysville, California
    • Skype @ KJ6RGX
    • Traveling RV Weather
Re: Freak Weather
« Reply #2 on: October 21, 2004, 01:48:49 AM »
My windchill went crazy today as well...I set it to only report windchill (I thought)...showing a couple of spikes today.
Re: Freak Weather
« Reply #3 on: October 21, 2004, 02:11:26 AM »
humm, seems like its doing even though its not supposed to
investigating
note: its not windchill going crazy, its plotting the heat index
ok, i  see...the windchill actualy goes above the temperature if the temperature is above 17oc (just the way the equation is). i did have that being checked, must have got broken
« Last Edit: October 21, 2004, 02:13:14 AM by windy »
Re: Freak Weather
« Reply #4 on: October 21, 2004, 02:19:01 AM »
uploading a new 10.18g now to fix this
(its still not going over 17oC here, its a cold spring we are having (but should warm up the next few days)
