Source data from weatherlink.com webpage with stationless
I Brian,
When is a new option to use the WD with data taken from the WeatherLink web pages ??
For example to get data from this page: http://www.weatherlink.com/user/sergly/index.php?view=summary&headers=1&type=1
:smiley: :smiley:
I am not sure if Davis would allow data scraping of their web servers
if you can get the OK, then I can add this
but why not get WD to get the data directly from the IP data logger ? (and set to release that, so WL.com is still updated)
Hi Brian, for the same reason for which WD use to get the data from metar or from clientraw.txt file…
had you ok from Davis to data scraping of their web servers ?
Cheers
Mario
I have not asked…thought that end users could…
I Brian
i had see that you added the weatherlink.com option to retreive data from WL.com page with DID KEY User and PASS.
It’s a great option for me… :smiley:
With the latest WD version the program do not retreive correctly min and max temp of the day and rainfall… It’s my problem?
Cheers
Mario
WD will have its own min/max, from live data,as it gets that data
I had not made it where it would use the max/min from weatherlink.com
I was not aware there was a problem with the rain…as rain is recorded on wlink.com and WD is running, then WD should increase its rain totals
I leave wd running up to 48 hours but the rain total
Not update…
humm
if you could email or PM me your wlink.com connection settings , when you have rain, and I will test/check here
It may depend by the rain unit set in mm?
I must set them in inches to correct WD work?
WD is expecting to see
<rain_day_in>
so yes, rain in inches
I must set console unit to inches?
If you could email me wlink.com settings then I can
See what’s happening
I Brian
today the rain is 0.6 mm
in the weatherlinkdata.txt i have <rain_day_in>0.0236</rain_day_in>
but in WD main screen is 0.0 mm or if i change unit in inches 0.000 in.
WD non t work with the rain :frowning:
I was out of office today, helping shift my daughter to housing for her university new year
Was WD running when the rain increase occured?
I will do some testing here, by manually adjusting the rain total value in the weatherlinkdata.txt file
OK, there was a bug with the rain data #-o 8O
I have fixed it
use the latest .zip update of WD
and the next rain increase, WD will now increase its rain total too
