Weather Display > WD Questions
Set-up New computer moved WD from one HD to other now tweeter does not update
tnwxman:
Had a computer failure. Got new computer and install old HD. Moved WD from old HD to new HD and did a new install of WD per forum instructions. Everything working fine exception Tweeter is not updating. The on button is in the on position. Have MS Net 4.0 installed. Running windows 7 Home Premium 64 bit. Any suggestions on how to get this fixed.
Bob
Weather Display:
try deleting the twitteroauth.txt files (there are 2 of them)
so that then you re setup for twitter
also make sure its .NET 4.0 extended (or is it client)
tnwxman:
Erased both files but no sucess. Microsift. Net Framework 4 Client Profile.
Bob
Weather Display:
could you provide more information other than no success?
i.e what happens when you click on test or run the wdtwitter direct
tnwxman:
Sure. When I click on the 'Test a data send' button nothing appears to happen. In the past I would see on occasion the twitter pop-up window quickly flash but not now. I then click on 'View your data' which takes me to my twitter page. Last entry is from right before my older computer failed on 8-7-12. I had not checked twitter until last night when I started following the local NWS forecast office.
Navigation
[0] Message Index
[#] Next page
Go to full version
