Weather Display > WD Bug Reports
RESOLVED: WD Control Panel Window wont open after upgrade to latest build.
Macca2:
Hi Guys,
I am the longtime WD user formerly known as "Macca".... however, my login details were no longer recognised, hence Macca2....
My WD system runs absolutley faultlessly, and I am loathe to change it. However, I upgraded to the new build last week, and since then, the WD application continues to operate as it should, but I cannot open the Control Panel or View windows. The drop down menus do work however. If I click on the Control Panel or View, all that happens is the WD windows goes grey, as if the window is already open? Really unusual. Have tried searching, I see one report from several years ago of a similar occurence, but he had no responses.
The program error log contains this:
Above error or program log occured at :04:20 pm 20/06/12
Cannot create file "C:\wdisplay\WDISPLAY.INI". The process cannot access the file because it is being used by another process
Above error or program log occured at :04:30 pm 20/06/12
Above error or program log occured at :05:20 pm 20/06/12
Above error or program log occured at :03:01 am 21/06/12
Above error or program log occured at :03:10 am 21/06/12
Above error or program log occured at :03:30 am 21/06/12
Above error or program log occured at :04:30 am 21/06/12
Above error or program log occured at :06:40 am 21/06/12
Any help much appreciated. #-o
Cheers
Macca(2)
Weather Display:
most likely a problem with the last window position settings
(can happen with more than one monitor)
you can reset those
in the wdisplay.ini settings file where WD is installed:
[control panel]
left=
top=
etc
delete those settings
(when WD is not running)
same for
[view panel]
left=
top=
Macca2:
Brian, as always, thankyou! For those who may come this way in the future - The above instructions have fixed the problem. :D
MitchM:
Hello,
I am having the same problem, I have 4 monitors running.
Win 7 64 bit, Davis VP2, WD 1037R Build 34
Unfortunately this solution has not worked for me. Any other options?
Thankyou,
Mitch
Weather Display:
that should do the trick
best thing is to .zip and email me your settings files
Navigation
[0] Message Index
[#] Next page
Go to full version
