Weather Display > WD Bug Reports
Email reports
aardvark:
for some odd reason, Wdisplay isn't sending me weather reports anymore. Didn't change settings, but it used to do it. I am not sure if it is something with my ISP or carrier. I did notice yesterday, my internet went down, I had to reboot the modem but it took right away.
I can get interwarn to send the mail but not WD from the same settings. Here is the ftpfull log:
Connecting to mail server.
Connected.
220 mx.google.com ESMTP g5sm2181261ign.4
EHLO Joseph-PC
250-mx.google.com at your service, [63.153.255.10]
250-SIZE 35882577
250-8BITMIME
250-AUTH LOGIN PLAIN XOAUTH
250 ENHANCEDSTATUSCODES
AUTH LOGIN
334 VXNlcm5hbWU6
d2VhdGhlcmFhcmR2YXJrQGdtYWlsLmNvbQ==
334 UGFzc3dvcmQ6
b2xkZmFydDE=
235 2.7.0 Accepted
Email sent OK 3:25:14 PM
*******actual messages from upload session********
***Start Time/date***:3:25:12 PM 6/15/2012
iaz060.txt
Permanent connection selected
Checking for what else to do...
there are 1 more things to do
Email date/time used Fri, 15 Jun 2012 15:25:13 -0500
Sending Weather Report Email
Connected.
EHLO Joseph-PC
250-SIZE 35882577
250-8BITMIME
AUTH LOGIN
334 VXNlcm5hbWU6
334 UGFzc3dvcmQ6
b2xkZmFydDE=
235 2.7.0 Accepted
165: Please specify a recipient (To).
Email sent OK
Finshed email agenda
Finished email agenda, no FTP items to do...
Doing abort procedure/program close...
JaxWeather:
It is possible the mail is being sent but you are not receiving it for some reason.
If you have other email addresses try putting them in and see if that address gets the message. best if the other email address is not on the same domain.
The first set of logs seem to indicate an OK send and the second also indicate an OK send but they do have this:
*dunno*
aardvark:
I went to each of the accounts and sent an email to the others, not sure either. I think I will do a couple of things. download a fresh whole copy and reboot the computer. reject my settings again and wait it out. I am pretty sure that it is the isp
aardvark:
started working. The only thing I could figure out different. I got an Iphone this week and on my PC there was the icloud control panel and I noticed in the systray it was loaded. so I shut it down for now and things appear to be working. I don't know if it was a lack of resources or that thing blocked the email from actually leaving the modem.
I will experiment on that later. If I ever get the opportunity to clean up the basement, then I will start the basement computer sending some things to take a load off this system.
fireman:
Mine has stopped too. It will not send out any emails unless I push the test button. Only thing that has changed, I upgraded to ver. # 10.37Q build 75 nothing else has been changed
Navigation
[0] Message Index
[#] Next page
Go to full version
