Weather Display > WD Questions
Help with webpage setup for dials
(1/1)
wellsweather:
Hello,
I have had some help with getting a custom home page setup that shows data in a table format and I have WD passing data to wxlocal.html file. I setup a redirect for the domain so that the index page is my custom home page.
Problem is that I have now lost the page that used to be the home page that WD was passing data to that showed the dials and rainfall data etc.
How can I get that back and displaying on my new page called live-weather.html
The website is www.wellsweather.co.uk
Sunny
wellsweather:
I think I figured it out... The display dails are generated with FLASH and it was a case of assigning the correct code.
Which leads to an associated question - the display will not play on an iPad because Apple does not support FLASH is there a better way of displaying the dials so that they can be rendered on an iPad?
Sunny
Weather Display:
there a couple of iphone applications that members of this forum have created
and there is also the "Steel gauges"
pwilman:
Peter,
My weather display live has some code that detects if you are on an iPad or iPhone and if you are it redirects you from the weather display live page to a page running the "steel series" code. If you search on this forum for steel series then you should be able to set it all up. The weather display live page I sent you has the iPad redirect code built in.
Let me know if you need help.
Paul
Navigation
[0] Message Index
Go to full version
