General > Chatter
Point me in the right direction
<< < (2/4) > >>
n7xrd:
--- Quote from: aardvark on April 28, 2012, 02:15:17 PM ---I can get an image downloaded to my PC.  I am in the process trying to get the movie to work.. there are so many tabs and they certainly all not used.  I assume one of them assembles all of the picture captures.
Then to load it back to the site.   I may figure this out before then next full moon, but I am a little less confident and exhuberant than I was 4 hours ago .
--- End quote ---
after you have the webcam capture setup leave it run and go to control panel open webcam again and use the video setup tab there hope this helps!!
aardvark:
the webcapture is running and I see files amassing.. so when does it produce a video?
I can't get it to snag from my IP directly but I have the D-link site updating every minute to my website folder and overwriting the previous image
http://www.weatheraardvark.com/Webcamera/DCS-932L.jpg
then to  upload it to the site.
Budgie:
With webcamcapture you should be getting the timestamped images saving in the folder of you choice with WD. Then you need the "Webcam" area of WD (Control Panel > Webcam) to build the videos, Brian wrote an FAQ on this part of it.  :wink:
aardvark:
I see that.   I am in the process of realizing what has to be running in the background...
still churning
aardvark:
I am getting the time stamped images, but when does it compile all these into a video/movie?   Do I need to be doing something else.  And where is Brian's FAQ?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
