Thanks for putting me right, I did as you said and the ROM ID is saved ok.
I also have an issue with the rain measurement on the main WD page.
The Rainwise outputs 0.25mm per tip which is 01. inches, however WD does not display enough decimal points in Metric. One decimal point is not enough, 2 decimal points would improve the Metric accuracy.
Thanks Marion..
