I cannot change the CWOP server port. It is stuck at 0. How do I change it?
Mike
Mike
oh
try changing that in the wdisplayftp.ini file
[Aprs data send]
other hub port=
I have the same problem. Ports always remain 0. I edited the wdisplayftp.ini and changed the port to 23. WD changes it right back to 0 after restarting the program. I am running Linux Mint 12. Any pointers on getting the changed ports numbers to stick? I have been running WD Linux for a week now. Uses 2% of the CPU. Looks good. I am looking forward to the new compiled version this fall. Happy WD user since 2001 Thanks Brian.
I will see if I can update with the current compiler used to fix that problem with not being able to set that cwop port
if you do not go into the cwop setup, it should not get reset though?
Before I would verify by going back into CWOP setup. After not going back into CWOP setup the port number stayed at 23. Thank you, I didn’t think of that.
Now I have to figure out why nothing happens after turning the switch on :oops:
