cloudy
Author Topic: Clientraw files stopped uploading, can't make it work again  (Read 509 times)
Offline casper
  • www.meteodelft.nl
  • Delft-The Netherlands
  • Mac OS X 10.7
  • Firefox 11.0
    • MeteoDelft
« on: April 06, 2012, 08:06:33 AM »
My clientraw files aren't uploaded anymore to my website, no reason at all. It happened after a internet interruption (restart router).
I restarted the mac mini on which wd is running on. Checked if the settings weren't changed somehow. Reentered the login details but still no upload activity
The log files says this:
Client raw FTP Upload 11:00:47 6-4-12
FTP real vers 2.9
Port to use 21
Passive mode on
logging on to meteodelft.nl
Log in failed
Result
uploaded /Library/Application Support/wdisplay/webfiles/clientraw.txt failed
Result
uploaded /Library/Application Support/wdisplay/webfiles/clientrawextra.txt failed
uploaded /Library/Application Support/wdisplay/webfiles/clientrawdaily.txt failed
Result 530 Please login with USER and PASS
But the user and pass is present in the configuration…
When I upload it manually, by means of cyberduck there are no problems at all. When updating my site, the login details also seem to be ok and I can reach everything through port 21.
As I said, I didn't change a thing. After the problem I downloaded the latest version of WD, but no change.
Can someone help me with this?
edit: I just came across the new ftupload. Started it, have to restart it frequently. Not working properly here.
Any suggestions?
« Last Edit: April 07, 2012, 09:41:05 AM by casper »
David Vantage Pro2 Plus
2x Vantage Pro Console (1 with logger)
solar+uv sensor
heated raingauge
running on MacMini (late 2009 / 10.7.3 Lion)
wd+wdl
http://www.meteodelft.nl
  • Davis VP1
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 12.0
    • Weather Display
Re: Clientraw files stopped uploading, can't make it work again
« Reply #1 on: May 28, 2012, 08:39:44 AM »
re the new clientrawrealtimeftp program
make sure you have set to restart instead of re login
in the real time ftp setup
in the latest test WD mac .zip update:
http://www.weather-display.com/downloadfiles/WeatherDmacnew.zip
build 99
sorry I missed seeing this thread
« Last Edit: May 28, 2012, 09:33:34 AM by Weather Display »
Offline casper
  • www.meteodelft.nl
  • Mac OS X 10.7
  • Firefox 12.0
    • MeteoDelft
« Reply #2 on: May 28, 2012, 06:55:56 PM »
No problem, you already replied by email
Unfortunately the only thing that helped was going back to version 60.
Since i did that everything is working properly again.
Afraid to update the program again.
solar+uv sensor
heated raingauge
wd+wdl
  • Davis VP1
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 12.0
    • Weather Display
« Reply #3 on: May 28, 2012, 08:28:58 PM »
I really need more testers of the new clientrawrealtimeftp program
to see if others have problems with it
before I release it
Offline casper
  • www.meteodelft.nl
  • Mac OS X 10.7
  • Firefox 12.0
    • MeteoDelft
« Reply #4 on: May 29, 2012, 07:59:15 AM »
I understand. The thing is that I don't have a test environment.
I installed the test you enclosed in the mail, but this version didn't work at my mac
solar+uv sensor
heated raingauge
wd+wdl
  • Davis VP1
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 12.0
    • Weather Display
« Reply #5 on: May 29, 2012, 10:03:59 PM »
I have a couple of other Mac uses using the new clientrawrealtimeftp version OK
maybe if you could email me your FTP settings I will test here and see if I get an error as well
Offline casper
  • www.meteodelft.nl
  • Mac OS X 10.7
  • Firefox 12.0
    • MeteoDelft
« Reply #6 on: May 31, 2012, 08:25:11 AM »
Hello Brian,
You should have them in your mailbox now
cheers
solar+uv sensor
heated raingauge
wd+wdl
  • Davis VP1
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 12.0
    • Weather Display
