Author Topic: SteelSeries Announcements  (Read 33544 times)
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win 7/Srvr 2008R2
  • Chrome 17.0.963.56
    • WilmslowAstro Weather
« on: February 22, 2012, 09:23:43 AM »
Latest version: 2.6.1
Want to make a donation to the Weather Gauges? Please click here.
I thought I would start a new thread for announcing the release of the latest version of the SteelSeries sample page/scripts. I'd like to keep this thread to just announcements and keep all support discussion on other threads, otherwise it quickly becomes unmanageable.
Please post support queries/discussions in this sub-forum
Download it from here
As usual, please take the time to read the readme.txt file, it does contain some useful information.
If you are interested in keeping up with SteelSeries releases I suggest you add a 'notify' to this thread.
The latest changes are...
2.6.1
  • Updated gauges.js
        - Fixed the odometer label colour not changing with the background colour.
2.6.0
  • Updated gauges.js
        - *Really* fixed scaling issues with rain gauge ;)
        - Added support for Weather Link/WL.com as a data source [Note requires a Saratoga template module]
        - Added title to Windrose odometer
  • Updated language.js/language.min.js
        - Added strings for mile, km, n_mile (nautical mile), used for WindRose odometer title
2.5.19
  • Updated gauges.js
        - Added tweak to rain gauge to fix constant redraws due to maxValue/maxScale mismatch when using default niceScale.
2.5.18
  • Updated gauges.js
        - Added CS tweak for WD users who normally use wxgraphs for the popup images, changes aspect ratio.
        - Now obeys the various default scale ranges in gaugeGlobals.[gauge]ScaleDef[Min|Max][unit] settings
2.5.17
  • Updated gauges.js
        - Added new config item "showWindMetar" to enable the METAR substring for wind on the direction gauge,
          the default is now disabled (was enabled). Previously you could only disable it by not showing any
          wind variation on the gauge.
Note: In order to try out different colour combinations and gauge styles, you can use my demo pages:
Radial Gauges, LinearGauges, Extra Gauges, StopWatch Gauge, Traffic Lights, Light Bulb, LCD Sections,
Wind Radar Gauge
« Last Edit: April 23, 2017, 02:48:36 PM by mcrossley »
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
Re: SteelSeries Announcements
« Reply #1 on: February 25, 2012, 06:36:18 PM »
For those who are notified of this thread, version 1.6.0 is now available.
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #2 on: February 26, 2012, 01:31:03 PM »
Version 1.6.0 introduced a lot of code changes and additions, so unfortunately there have been a few bugs I missed.
Version 1.6.2 is now available which addresses all the ones I know about.
Mark
Offline Sask
  • Sussex NB, Canada to Dargaville NZ
  • Win 7/Srvr 2008R2
  • Firefox 10.0.2
    • Mahuta Rd, Dargaville - New Zealand
« Reply #3 on: February 26, 2012, 07:15:44 PM »
Download seems to be timing out for me.
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #4 on: February 27, 2012, 08:36:16 PM »
v1.6.3 posted, this fixes the last known (ha ha!) bug introduced by the 1.6 changes - the maximum average temperature reading.
I also taken the opportunity to do a long overdue tidy up the graph handling in the popups.
There is a new variable (g_showPopupDataGraphs) which allows you switch off the graphs completely and just leave text based popups.
All the graph images are now defined in gauges.js by the g_tipImgs array - you no longer need to edit the ddimagetooltips.js as well. This array has also been expanded; by default it is configured with the 'standard' Cumulus trend images, but you can now add your own custom graphs for every gauge reading such separate graphs for dewpoint, apparent, windchill, indoor humidity etc. You can also add graphs for UV and Solar Radiation which Cumulus does not generate at all. WD users should find this feature useful.
« Last Edit: February 28, 2012, 08:44:49 AM by mcrossley »
Mark
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win 7/Srvr 2008R2
  • Firefox 10.0.2
    • Weather Display
« Reply #5 on: February 28, 2012, 02:55:30 AM »
thanks very much for all your hard work mcrossley :)  :)
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #6 on: March 01, 2012, 06:03:12 PM »
Not hard enough Brian!
Version 1.6.4 now available, it fixes the shaded min/max not being displayed on the temperature gauges. Only gauges.js changed this time.
Mark
Offline Weerstation
  • The Netherlands
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« Reply #7 on: March 01, 2012, 10:29:15 PM »
Thanks for all the hard work.
I noticed some spelling errors in the Dutch translation:
moderndere - modernere
should be a space between 'oude' and meters
weeerstation - weerstation
Data laten - Data laden
Buitentemperatur - Buitentemperatuur
Binnentemperatur - Binnentemperatuur
Gevoelstemperatur - Gevoelstemperatuur
Abbreviation for the month of March (Maart), I'd prefer Mrt instead of Mar
« Last Edit: March 01, 2012, 10:56:11 PM by Weerstation »
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37R build 81 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #8 on: March 02, 2012, 02:10:46 PM »
For the more adventurous go-it-a-loners, I have just released a new version of the full SteelSeries library (v0.11.0). Read about it here:
https://plus.google.com/b/105784522827877256999/105784522827877256999/posts/SHdS6acMpkt
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #9 on: March 08, 2012, 11:28:39 AM »
Version 1.6.5 now available, quite a few changes again in this release, maybe it should have been a 0.1 update! :lol:
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
  • Chrome 17.0.963.79
« Reply #10 on: March 19, 2012, 12:14:58 PM »
Version 1.6.6 now available.
One fix that you may want to incorporate soon, v1.6.5 downloads the humidity graph every realtime update cycle rather than every 15 minutes (default). The change if you just want to edit your existing file is line 1336, changes from:
Code: [Select]
        if (g_showPopupDataGraphs && g_tipImgs[4][0] !== null) {
to
Code: [Select]
        if (g_refreshGraphs && g_showPopupDataGraphs && g_tipImgs[4][0] !== null) {
Also added Danish and Finnish translations.
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #11 on: March 19, 2012, 07:48:26 PM »
The rain rate gauge hasn't been working correctly with WD, I have attached an updated customclientrawlocal.txt file to the first post, please replace teh version in 1.6.6 with this file until the next release when I'll roll it in.
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
  • Chrome 18.0.1025.162
« Reply #12 on: May 09, 2012, 07:32:31 PM »
I have updated the SteelSeries library to version 0.11.3...
These changes speed up the library quite a bit so I thought it would be worth providing an updated Weather Gauge specific version (as I normally supply the  weather gauges releases). This 'should' be a drop in replacement for the existing file on your server.
The main changes are:
> Radial
  * Fixed Odometer being reinitialised every time the background was redrawn
  * Fixed background changes drawing LCD background when Odometer visisble
  * Disabled pointer shadow blurring, it was causing performance issues in some browsers
  * added check for 'knob' parameter in drawRadialForegroundImage()
> Odometer
  * Added setValueAnimated() method
> RadialBargraph
  * Fixed issue with LED halo still displaying when LED was off
> General
  * Added full caching to: trendIndicator, MaxMinIndicators, LCDbackground, LEDimage,
    LinearForeground, LinearBackground, LinearFrame,
    RadialForeground, RadialBackground, RadialFrame, and RadialPointers
  * Stopped some variable leakage to the global scope
  * Some code styling changes and fixes for minor syntax niggles
EDIT: Script updated, see below...
« Last Edit: May 11, 2012, 02:02:06 PM by mcrossley »
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
« Reply #13 on: May 11, 2012, 02:01:31 PM »
Opps, the last version of the cutdown SteelSeries script was a little too cut down - I left out the Odometer component. This version adds it back in again, it only really affects you if you use the odometer display on a gauge.
« Last Edit: December 20, 2012, 10:26:19 AM by mcrossley »
Mark
Offline mcrossley
    • none
  • Win 7/Srvr 2008R2
  • Chrome 23.0.1271.97
« Reply #14 on: December 20, 2012, 10:28:20 AM »
Version 2.0.0 is now out of beta and available. Enjoy  :santa:
Mark
