I purchased the component (68$ US)
added to build 10
uses wdlconfig.xml
which if that does not exist in the clientraw location , its copied there from the default install location ( using a default one)
you can then use WDL configurator to configure that xml settings file if you wish
I often have seen comments about how much people like WDL and if WD could be like WDL it would be great....well now it can...
also note that the registration number is any 10 digit number to remove the evaluation version wording if running on the local PC like this is
also note that if you have a clientraw.txt file where WD is installed, it will use that...delete that...unless that is where you have set the clientraw location (instead of say the web files folder)
I have added option to show a background image and also added option to have the WDL screen show when WD starts up
(one good thing about the screen is it resizes nicely
Julian is all for this
I think this is a nice addtion
