cloudy
Author Topic: CWOP test works but no auto update  (Read 425 times)
Offline BillVan
  • Texas
  • Win 7/Srvr 2008R2
  • MS IE 9.0
« on: January 12, 2012, 01:03:00 PM »
title says it all.... WU updates fine, on CWOP, hit the TEST button and it uploads but nothing after that. Thanks in advance for help
Bill W5WDV
Online JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
  • Win 7/Srvr 2008R2
  • Firefox 10.0
    • JaxWeather.net
Re: CWOP test works but no auto update
« Reply #1 on: January 12, 2012, 02:20:48 PM »
Have you checked your CWOP logs (from CWOP) and see if the raw data is getting there?  Also how long since you first started sending data?  And what does your FTP logs show, any information there?
  • Win 7/Srvr 2008R2
  • Firefox 9.0.1
« Reply #2 on: January 12, 2012, 08:30:46 PM »
make sure the main internet switch is on
and you have set to use weather display's ftpupd.exe in the connections setup
and that you have times set to send in the cwop setup
also make sure you have not set to positionless mode under setp, aprs setup
Offline BillVan
  • Texas
  • iOS 5.0.1
  • Safari 5.1
« Reply #3 on: January 14, 2012, 09:01:50 PM »
Thanks for the responses, currently out of town but will check suggestions on Monday when I return. Bill
Offline BillVan
  • Texas
  • Win XP
  • Firefox 8.0
Re: CWOP test works but no auto update SOLVED
« Reply #4 on: January 16, 2012, 09:31:05 PM »
Guess I'm getting old, the time offset was wrong. Up and running now and all is reporting correctly. Thanks for the help!
Bill
Online JaxWeather
  • Bob
  • Global Moderator
  • Win 7/Srvr 2008R2
  • Firefox 10.0
    • JaxWeather.net
« Reply #5 on: January 16, 2012, 09:57:12 PM »
Good deal Bill,
Thanks for the follow-up it may help others down the road :)
