cloudy
Author Topic: I am starting to feel a little defeated in trying to setup a Carter Lake.  (Read 1586 times)
Offline n7xrd
  • Steve
  • Renton,Wa.
    • Renton,Wa. Weather
Re: I am starting to feel a little defeated in trying to setup a Carter Lake.
« Reply #30 on: December 15, 2011, 01:15:40 AM »
How's it going made any progress??
Offline Sask
  • Sussex NB, Canada to Dargaville NZ
    • Mahuta Rd, Dargaville - New Zealand
« Reply #31 on: December 15, 2011, 01:39:39 AM »
Well tbh, I think I am starting to get a handle on it. I understand how the web folder should be laid out when you unzip the template etc. Have read the instructions on the links you provided and my eyes don't gloss over when reading them now.
I got the MATAR working (had forgotten the .txt initially). I have successfully updated my main apache web server to  handle PHP. Zipped up my working web folder (as backup). I am going to attempt to get Saratoga working on the main WD/Web server setup (this may take me awhile to get going, stand by).
« Last Edit: December 15, 2011, 01:41:46 AM by Sask »
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #32 on: December 15, 2011, 01:47:03 AM »
Let me know if I can help at all I am not an expert but I've done alot of setup on my site...not without the help of this forum!! :D
Offline Sask
« Reply #33 on: December 15, 2011, 01:59:16 AM »
pm'd you.
Offline Sask
« Reply #34 on: December 15, 2011, 04:07:16 AM »
Thanks Steve so much for coming on and having a look on my computer. Least we have an idea on my problem.
Guess the problem I am having is Saratoga PHP files will not work. Yet the generated PHP file by WD works fine (in the Web Files #1). If I copy the source from another persons front page and put it in...it loads up (of course not entirely properly)..but it loads vs no loading at all.
Can anyone think of a reason why the Saratoga PHP files wouldn't load? Some setting?
I am learning lots...my head hurts a little...but I am learning.
« Last Edit: December 15, 2011, 04:09:06 AM by Sask »
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #35 on: December 15, 2011, 11:43:46 AM »
can't figure out why index.html will load and run fine but wxindex.php or any of the .php files which are in the same folder will not work I get a page not found on these??  8O #-o
« Last Edit: December 15, 2011, 01:38:11 PM by n7xrd »
Offline Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
« Reply #36 on: December 15, 2011, 12:12:40 PM »
I take it that you have PHP available on the home server?
If HTML pages are working and PHP one's are not then I would check that first.
Have a look at Ken's PHP test page and run through that: http://saratoga-weather.org/scripts.php#PHPTest
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #37 on: December 15, 2011, 12:26:33 PM »
Yes that was ran and it said it was working just fine and when he takes say my .php file and sticks it in his folder it will
run but of course will not display correctly on his system...
Offline Sask
« Reply #38 on: December 15, 2011, 09:32:15 PM »
Would running PHP Version 6.0.0-dev cause any issues? It is the version I am running.
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #39 on: December 15, 2011, 09:41:45 PM »
  Here's from Kens site.."you should make sure that your site is configured to run PHP5+ for all .php pages."
Offline Sask
« Reply #40 on: December 15, 2011, 09:46:57 PM »
This loads up fine - http://mahutaweather.no-ip.org/test.php - disabled...guess I don't want this out and about  :oops:
This is using one of the Saratoga downloaded php's - http://mahutaweather.no-ip.org/wxindex.php
« Last Edit: December 15, 2011, 09:55:17 PM by Sask »
Offline n7xrd
  • Steve
  • Renton,Wa.
« Reply #41 on: December 15, 2011, 09:48:33 PM »
go to the custom templates and scripts section and post this again maybe Ken will advise??
Offline Sask
« Reply #42 on: December 15, 2011, 09:52:29 PM »
I'll throw this in as well - copied off another site's front page - http://mahutaweather.no-ip.org/copiedsite
Offline Sask
« Reply #43 on: December 16, 2011, 06:13:18 PM »
Just though I would make an update...it is working  :D, needs some tweaking of course.
Seems the problem was with the version of PHP I was running. Doesn't like PHP 6.0 for some reason. After I downgraded 6.0 to 5.2 page came up. I did a little dance when it worked :wav:
Thnks for the help. And thank you even more to n7xrd and Ken.
