cloudy
Author Topic: Found a new way to handle the HID USB using API  (Read 966 times)
Offline ejeklint
  • Mac OS X 10.7.3
  • Safari 5.1.3
Re: Found a new way to handle the HID USB using API
« Reply #15 on: January 23, 2012, 09:08:54 PM »
Cool. Let me know if I can assist. Remote debugging is kind of fun.  :D
  • Win 7/Srvr 2008R2
  • Firefox 9.0.1
« Reply #16 on: January 23, 2012, 09:17:19 PM »
am trying to work out from your project code how to call to get data
can you post a code snippet?
thanks
I do see you have had to check on the type of data for the expected length etc
Offline ejeklint
  • iOS 5.0.1
  • Safari 5.1
« Reply #17 on: January 23, 2012, 09:44:19 PM »
Ok, will get some code to you tomorrow. Must get some sleep now.
Offline ejeklint
  • Mac OS X 10.7.3
  • Safari 5.1.3
« Reply #18 on: January 24, 2012, 07:04:09 AM »
thanks
OK, the thing is that you don't call anything to get data, you get called to receive data. The callback function Handle_IOHIDDeviceInputReportCallback is there for that. Easiest thing to do is move that function to your own code and just leave an external declaration of it in hiddevice.c. After calling Setup_HIDManager, data should start to come in.
Data is packed in a "report", where the first byte tells how many of the consecutive bytes are valid data. It's usually 1 byte for each report (at least for Oregon stuff), but you shouldn't rely on it. This example is in Objective-C, but you'll get the point on how to extract valid bytes and assemble data: https://github.com/ejeklint/Cloudya/blob/master/daemon/WMR100NDeviceController.m#L136
An alternative solution that makes assumptions of package lengths for assembling a complete data package from Oregon stations, which I just wrote in JavaScript for node.js, is this:
WMR100Controller.prototype.weatherData = function (error, data) { // "data" is the buffer with the Device Input Report
    if (ffs === 2) { // ffs is a counter
        // Two consecutive 0xff is detected, we are in sync! Start saving data until next two 0xff
        for (var i = 0; i < data[0]; i++)
            inbuf[ii++] = data[1 + i]; // Keep saving valid bytes in a buffer
        // Check expected lengths. We know what from looking at the second byte after the sync-ffs.
        if (expectedLength === 0 && ii > 5) {
            switch (inbuf[1]) {
                case 0x41:
                    expectedLength = 17;
                    break;
                case 0x42:
                    expectedLength = 12;
                    break;
                case 0x46:
                    expectedLength = 8;
                    break;
                case 0x47:
                    expectedLength = 6;
                    break;
                case 0x48:
                    expectedLength = 11;
                    break;
                case 0x60:
                    break;
                default:
                    // Unknown. Trash it and start looking for new frame
                    ii = ffs = expectedLength = 0;
        if (ii === expectedLength) {
            // Complete reading from weather station is acquired, toss it on!
            this.emit('sensor' + inbuf[1].toString(16), inbuf.slice(0, expectedLength));
            // Start looking for new frame
    } else if (ffs === 1 && data[1] !== 0xff) {
        ffs = 0;
    } else if (data[1] === 0xff) {
        ffs++;
    // Re-bind this callback to node-hid module
    this.hid.read(this.weatherData.bind(this));
HTH.
  • Win 7/Srvr 2008R2
  • Firefox 9.0.1
« Reply #19 on: January 24, 2012, 05:41:04 PM »
ah, gotcha, is basicly an interupt call
I will try that
I did see where you had put, put your code here...
let me see what I can do (C or C++ is not my prefered language, but google is great!)
  • Win 7/Srvr 2008R2
  • Firefox 9.0.1
« Reply #20 on: February 14, 2012, 07:57:52 AM »
I have upgrade to snow leopard, 10.6.6
i.e with a new Xcode upgrade etc
so should have more chance of compiler your sample code
do you think you could send me a simple program to get data from the wmr100 so that I can use that as a basis to work on?
Thanks!
