Author Topic: Windows 7 , wireless and wired at same time  (Read 2126 times)
Offline aardvark
  • Des Moines, Iowa
  • Des Moines, Iowa, USA
« on: November 19, 2011, 10:42:35 PM »
I am still tooting around with this CPU replacement.  It is a  Gateway Dx4860  and is a bit different than my HP.
My question is that it has both the wireless card antenna on board and active which gives a 72Mbps connection.  I also have the ethernet cable going to the same DSL modem  and it claims 1Gbps  connection.
I am attaching two settings pictures.
I cannot map the connections because for some reason the wireless setting is on public.  I hear it is a flaw in the windows 7 structure... for some reason the wireless is alway listed as public.
In any case,   do I need both of them going at the same time, or should I disable the wireless.    I have no way to know if the internet connection is going to the 1Gbps or the 72 mbps.
The question is, should I just leave it alone, disable the 72mbps.    I know I disabled the ethernet connection and lost my internet connection ...
Davis VP2 Plus; 24h  FARS; Extra Temp Humid sensor (2); Extra Temp Station (2); Soil Moisture/Temp Station;Weatherlink IP;USB; MAC Sierra; Bloomsky Sky2 ; https://map.bloomsky.com/weather-stations/faBiuZWsnpW6n6il;
http://www.desmoinesweather.org
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: Windows 7 , wireless and wired at same time
« Reply #1 on: November 19, 2011, 11:03:26 PM »
Disable the wireless, you only need one and the hardwire will be the fastest and most reliable.
Offline aardvark
  • Des Moines, Iowa
« Reply #2 on: November 19, 2011, 11:07:03 PM »
I had wondered if it was related to my network.. oh  I forgot to attach the pictures ( I had the thought of a cup of hot apple cider in mind at the same time... I'll blame it on old age creeping in).
Offline aardvark
  • Des Moines, Iowa
« Reply #3 on: November 19, 2011, 11:18:36 PM »
switched it off and we'll see how things go.
Offline ALITTLEweird1
  • Mark
  • Global Moderator
  • North Bend, WA
    • North Bend Weather
« Reply #4 on: November 19, 2011, 11:26:59 PM »
Unless someone is connected to you using wireless, you wont notice a difference. I always leave mine off.
"Nature can do without man, but man cannot do without nature."
Davis VP2 + VP2 Solar + Logitech Webcam
Offline niko
  • syzygy
  • Global Moderator
« Reply #5 on: November 19, 2011, 11:27:17 PM »
Strange that the wired connection is showing as "Shared"  :?
Offline aardvark
  • Des Moines, Iowa
« Reply #6 on: November 20, 2011, 12:35:50 AM »
it is shared..  I have the direct TV goes into the modem as well as the connection to the weather computer in the basement.  In my infinite desire not to go down into the cold basement, I have the computer down there using the home network print to my laser printer.  It prints those end of the month reports WD so nicely does.
I do check the system often to besure I don't have anyone hackng in..  I doubt they could with the security, but there are 4 people with DSL wireless, the ladies next door, and some neighborhood slugs with their dopey kids.    The ladies are great.. they trim my lilac hedge, clear off the sidewalk when it snows and have never complained of the weather station because the hedge hides it from their side.    One is an engineering student at Iowa State and the other works for a chemical company in research -  a flavorings concern.
Offline niko
  • syzygy
  • Global Moderator
« Reply #7 on: November 20, 2011, 12:43:07 AM »
Are you saying that the printer is connected directly to the PC (USB or parallel) and the other PC's print to it via the network?
Offline aardvark
  • Des Moines, Iowa
« Reply #8 on: November 20, 2011, 01:14:49 AM »
yes
