cloudy
Author Topic: Problem with Ubuntu install - was How to uninstall WD?  (Read 4198 times)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« on: August 25, 2011, 12:53:43 AM »
How does WD uninstall? I need to start over but I don't see it in the package list  :?  (Unbuntu)
« Last Edit: August 25, 2011, 02:34:21 AM by niko »
Re: How to uninstall WD?
« Reply #1 on: August 25, 2011, 01:26:14 AM »
just deleting the folder where its installed to (and any subfolders) should be enough
Offline niko
  • syzygy
  • Global Moderator
« Reply #2 on: August 25, 2011, 01:32:27 AM »
OK, I'll give that a try.
Offline niko
  • syzygy
  • Global Moderator
Re: Problem with Ubuntu install - was How to uninstall WD?
« Reply #3 on: August 25, 2011, 02:36:06 AM »
Hmmm, so I deleted it all. Downloaded a fresh one, extracted and installed it and I have the same problem, no menu  :oops: This is the latest Ubuntu.
Offline jloflin
  • El Paso, Texas, USA
« Reply #4 on: August 25, 2011, 02:50:09 AM »
You shouldn't have to install it. I just downloaded it, extracted it, switched to the folder /wdisplay and run WeatherD.
Randy
Offline niko
  • syzygy
  • Global Moderator
« Reply #5 on: August 25, 2011, 03:24:51 AM »
My WeatherD doesn't run. I was following other posts on here that say to run GoWeather.sh.
« Reply #6 on: August 25, 2011, 03:45:13 AM »
if you try to run from a console window, where WD is installed to
as
./WeatherD
what error shows up?
Offline marfanuk
  • Cheshire, UK
    • My exotic garden in the UK
« Reply #7 on: August 25, 2011, 08:13:24 AM »
mine doesn’t run from weatherD, but runs fine from GoWeather.sh. I don’t run it from a terminal, just from the folder.
I’m running the GUI version.
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« Reply #8 on: August 25, 2011, 09:23:17 AM »
I've been trying to test WD under Linux for a few months now on and off. My problem is that I wanted to use TCP/IP connectivity to VirtualVP but when I open the control panel for the connection the TCP/IP section for VVP is blank. Does Linux WD (GUI version) not support this now? Can anyone else confirm that this panel is blank?
Offline marfanuk
  • Cheshire, UK
« Reply #9 on: August 25, 2011, 09:38:15 AM »
I never used the TCP/IP area, but i do have stuff on it rather than a blank screen . see image.
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #10 on: August 25, 2011, 10:30:36 AM »
No not that one, its on the Com port selection screen, there is a tab for it.
Offline marfanuk
  • Cheshire, UK
« Reply #11 on: August 25, 2011, 11:21:00 AM »
Stuart, just checked and mines blank too.
Offline niko
  • syzygy
  • Global Moderator
« Reply #12 on: August 25, 2011, 01:44:20 PM »
as
./WeatherD
admin2@ubuntu:~/wdisplay$ ./WeatherD
./WeatherD: error while loading shared libraries: libusbdll.so: cannot open shared object file: No such file or directory
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #13 on: August 25, 2011, 03:54:38 PM »
That's what happens when you run directly because it has not added the library which is what the script does. Right now I have a different problem where WD wont run, so I'll open a new thread for that once I'm sure it's not me!
« Reply #14 on: August 25, 2011, 05:44:38 PM »
Niko, you will need to first copy the library files to
/usr/
broadstairs, I have not had a chance to look into the TCP/IP yet
