You mean WD must see the date and time without the /s and :s? Do I fix that in the Meteobridge setting or do you fix the WD? I’m not sure at this point if I can change anything, however.
Aloha,
Mark
Aloha,
Mark
Brian One other thing I could not get WD Mac224 to run from terminal command it would start than crash. I just started wd by clicking on the icon and it start right up and retrieved the last 20min of data and is running. #-o
BTrip
that error about the max axis I am sure I have fixed in the latest update…make sure you have that
@ mswatanabe
post a screen shot of the sun moon rise/set up in WD
also what shows under view, program event log, in the latest update
Here they are.
Aloha,
Mark
I ran build 223 from terminal and saw this error message when WD quit:
Exception EAccessViolation in module weatherdisplay at 0003880F.
Access violation at address 9008EA95, accessing address 01572000.
Runtime error 0 at 0003880F
logout
[Process completed]
There is also this message that is repeated about 4 times per second:
2015-06-18 20:02:59.923 weatherdisplay[53408:507] CoreText performance note: Client called CTFontCreateWithName() using name “Times New Roman” and got font with PostScript name “TimesNewRomanPSMT”. For best performance, only use PostScript names when calling this API
I have not tried build 224 yet as there are reported issues so I’ll wait before trying that
Paul
Add:: I checked the times of file uploads using the Internet File Creation Uploads and the one file that is close to the time stamp of when WD quit is File #11 Cur. 24/48/72 hr graphs. I have that file being created at :03 past the hour and uploaded at :04 past the hour
This happened again the next hour at the same time so it appears to possibly be the File 11 creation/upload causing the access violation. Tomorrow I will turn off that file and try again. Back to B 24 for the night.
Hi Brian, I downloaded WD Mac224 again and reinstall, No crashes on startup Have screen shoot of event log and will post Debug info & FTP log. Run from terminal will post.
Terminal Error
tcsetattr Set error
Restoring the tty configuration
Error closing the tty
Debug Info
Loaded all time records
Loaded units
Comport open OK
connected OK to com port /dev/tty.KeySerial1
*sending DMPAFT
Asking for archived data download
data length 3
Asking for data
Davis VP Retrieving data from: day 18 month 6 year 2015
Retrieving data from: hour 19 minute 1
data length 7
sending OK
data length 267
***formating data
Time :18:59
Date :06/18/2015
***formating data
Time :19:00
Date :06/18/2015
***formating data
Time :19:01
Date :06/18/2015
***formating data
Time :19:02
Date :06/18/2015
*formating data
Time :19:03
Date :06/18/2015
finished data block
sending OK after 5 blocks of data
All data downloaded or did not sync correct!
formating the VP data
vp data read in 2
VP data Date:= 18/6/2015
VP data Time:= 19:2
Rain in davis VP download added :0.00
Comport open OK
Weather station type number 31
**** running cronftpreal
FTP Log
FTP vers 1.7 Upload 18:56:04 18-6-15
Port to use 21
Passive mode on
logging on to southwestweather.com
login OK to southwestweather.com
Change directory Ok to /public_html/wx/
Result 250 OK. Current directory is /public_html/wx
Local files list - > /Library/WebServer/web/wx/noname.gif 0
Local files list - > /Library/WebServer/web/wx/dailyhighlowbaroetc.gif 1
Local files list - > /Library/WebServer/web/wx/wx.html 2
Local files list - > /Library/WebServer/web/wx/testtags.php 3
Local files list - > /Library/WebServer/web/wx/summary.jpg 4
Local files list - > /Library/WebServer/web/wx/dirplot.gif 5
Local files list - > /Library/WebServer/web/wx/dirplotspd.gif 6
Local files list - > /Library/WebServer/web/wx/dirplot2.gif 7
Local files list - > /Library/WebServer/web/wx/forecasticon.gif 8
Local files list - > /Library/WebServer/web/wx/forecasticonmetar.gif 9
Local files list - > /Library/WebServer/web/wx/forecasticonstation.gif 10
Local files list - > /Library/WebServer/web/wx/localweather.gif 11
Local files list - > /Library/WebServer/web/wx/weatherbanner.gif 12
Local files list - > /Library/WebServer/web/wx/yowindow.xml 13
Remote files list - > noname.gif 0
Remote files list - > dailyhighlowbaroetc.gif 1
Remote files list - > wx.html 2
Remote files list - > testtags.php 3
Remote files list - > summary.jpg 4
Remote files list - > dirplot.gif 5
Remote files list - > dirplotspd.gif 6
Remote files list - > dirplot2.gif 7
Remote files list - > forecasticon.gif 8
Remote files list - > forecasticonmetar.gif 9
Remote files list - > forecasticonstation.gif 10
Remote files list - > localweather.gif 11
Remote files list - > weatherbanner.gif 12
Remote files list - > yowindow.xml 13
File to upload → /Library/WebServer/web/wx/noname.gif
uploaded noname.gif OK
File to upload → /Library/WebServer/web/wx/dailyhighlowbaroetc.gif
uploaded dailyhighlowbaroetc.gif OK
File to upload → /Library/WebServer/web/wx/wx.html
uploaded wx.html OK
File to upload → /Library/WebServer/web/wx/testtags.php
uploaded testtags.php OK
File to upload → /Library/WebServer/web/wx/summary.jpg
uploaded summary.jpg OK
File to upload → /Library/WebServer/web/wx/dirplot.gif
uploaded dirplot.gif OK
File to upload → /Library/WebServer/web/wx/dirplotspd.gif
uploaded dirplotspd.gif OK
File to upload → /Library/WebServer/web/wx/dirplot2.gif
uploaded dirplot2.gif OK
File to upload → /Library/WebServer/web/wx/forecasticon.gif
uploaded forecasticon.gif OK
File to upload → /Library/WebServer/web/wx/forecasticonmetar.gif
uploaded forecasticonmetar.gif OK
File to upload → /Library/WebServer/web/wx/forecasticonstation.gif
uploaded forecasticonstation.gif OK
File to upload → /Library/WebServer/web/wx/localweather.gif
uploaded localweather.gif OK
File to upload → /Library/WebServer/web/wx/weatherbanner.gif
uploaded weatherbanner.gif OK
File to upload → /Library/WebServer/web/wx/yowindow.xml
uploaded yowindow.xml OK
Logging off
BTrip
they have not been to do with your weather station type though
There is also this message that is repeated about 4 times per second:2015-06-18 20:02:59.923 weatherdisplay[53408:507] CoreText performance note: Client called CTFontCreateWithName() using name “Times New Roman” and got font with PostScript name “TimesNewRomanPSMT”. For best performance, only use PostScript names when calling this API
I am not able to duplicate a problem here with file #11 creation , so must be something in your settings
Build 226 disk image won’t open. Error window attached.
Aloha,
Mark
ops
try again now
Build 226, something’s still wrong. See attached.
Aloha,
Mark
does that UTC time conversion look correct?
also what do you set as the meteohub IP address in the com port setup?
I am trying to reset the Solar blocked color but cannot do so.
I go to Control Panel > Color / Font Setup > Graphs Colour/Font
I click on the button for Solar Blocked Color which is currently set to Aliceblue. I use the arrow keys to scroll to Yellow. I then reclick the button to set. Click OK but the color does not reset.
Also, I have moved all my data over from WD Windows. How do I reset the all time and monthly records?
UPDATE: The Control Panel > Data Logger > Set the Time/Date to Get The Data From does not work.
Hugh
Hi Brian WD MacB224 ran over night and all is good. All webpage history data uploaded to website. Downloading WD Mac226 will install when download is complete.
Debug Log WB B224
Reset overnight minimum temp 21:00:01 06/18/15
Reset overnight minimum temp 21:01:00 06/18/15
Normal daily resetting wind/temperature daily value , day: 19
Normal daily resetting rain daily value , day: 19 rain today 0.0 mm
Program Event Log WD B224
The specified file was not found
Brian,
I want to show soil temperature on my main window.
On another thread about WD Windows you explained how to do this. You said:
“and then go to setup, advanced/misc, wind section and untick to show wind run on main screen
then the soil temperature should show up”
This works on WD Windows. However, on WD Mac, if I untick to show wind run, I get wind speed right below the wind gauge.
If I tick it I get nothing.
Hugh
Hi Brian install WD Mac226 it is up and running no problems with in install :). Debug log look good, FTP Error Log looks good, Program Event Log looks good. Finger cross for noon for logging data
Debug Log WD Mac226
Loaded units
Comport open OK
*sending DMPAFT
data length 3
Asking for data
Davis VP Retrieving data from: day 19 month 6 year 2015
Retrieving data from: hour 5 minute 52
data length 7
sending OK
data length 267
***formating data
Time :05:49
Date :06/19/2015
***formating data
Time :05:50
Date :06/19/2015
***formating data
Time :05:51
Date :06/19/2015
***formating data
Time :05:52
Date :06/19/2015
*formating data
Time :05:53
Date :06/19/2015
finished data block
data length 267
***formating data
Time :05:54
Date :06/19/2015
***formating data
Time :05:55
Date :06/19/2015
***formating data
Time :05:56
Date :06/19/2015
***formating data
Time :11:17
Date :06/17/2015
**formating data
Time :11:18
Date :06/17/2015
finished data block
vp data read in 4
VP data Date:= 19/6/2015
VP data Time:= 5:53
VP data Time:= 5:54
VP data Time:= 5:55
Adding wunderground data to the missed data file 5:55
missed wunderground hour normal 5
missed wunderground hour from logger 5
missed wunderground hour difference 0
missed wunderground new hour /day/normalday 5 19 19
missed wunderground new time 06/19/2015 05:55:00
Comport open OK
Program Event Log
Current coldest night value (oC) 32.0 06:00:00 06/19/15
Resetting warmest day values 06:00:31 06/19/15
FTP Error Log WD Mac226
FTP vers 1.7 Upload 06:02:05 19-6-15
Port to use 21
Passive mode on
Local files list - > /Library/WebServer/web/wx/moondetail1.gif 0
Local files list - > /Library/WebServer/web/wx/moondetail2.gif 1
Local files list - > /Library/WebServer/web/wx/noname.gif 2
Local files list - > /Library/WebServer/web/wx/dailyhighlowbaroetc.gif 3
Local files list - > /Library/WebServer/web/wx/wx.html 4
Local files list - > /Library/WebServer/web/wx/testtags.php 5
Local files list - > /Library/WebServer/web/wx/summary.jpg 6
Local files list - > /Library/WebServer/web/wx/dirplot.gif 7
Local files list - > /Library/WebServer/web/wx/dirplotspd.gif 8
Local files list - > /Library/WebServer/web/wx/dirplot2.gif 9
Local files list - > /Library/WebServer/web/wx/forecasticon.gif 10
Local files list - > /Library/WebServer/web/wx/forecasticonmetar.gif 11
Local files list - > /Library/WebServer/web/wx/forecasticonstation.gif 12
Local files list - > /Library/WebServer/web/wx/localweather.gif 13
Local files list - > /Library/WebServer/web/wx/weatherbanner.gif 14
Local files list - > /Library/WebServer/web/wx/yowindow.xml 15
Remote files list - > moondetail1.gif 0
Remote files list - > moondetail2.gif 1
Remote files list - > noname.gif 2
Remote files list - > dailyhighlowbaroetc.gif 3
Remote files list - > wx.html 4
Remote files list - > testtags.php 5
Remote files list - > summary.jpg 6
Remote files list - > dirplot.gif 7
Remote files list - > dirplotspd.gif 8
Remote files list - > dirplot2.gif 9
Remote files list - > forecasticon.gif 10
Remote files list - > forecasticonmetar.gif 11
Remote files list - > forecasticonstation.gif 12
Remote files list - > localweather.gif 13
Remote files list - > weatherbanner.gif 14
Remote files list - > yowindow.xml 15
File to upload → /Library/WebServer/web/wx/moondetail1.gif
uploaded moondetail1.gif OK
File to upload → /Library/WebServer/web/wx/moondetail2.gif
uploaded moondetail2.gif OK
uploaded wx.html OK
Thanks Again
Btrip
I’ll check all the above, thanks.
Looks like the time isn’t being read correctly, but I’m not sure anymore. The logs are attached.
Up until now, I left the IP address as what was entered by WD, but that was 10.0.1.16, which is the address of the Davis Datalogger itself. The Weatherbridge IP address is 10.0.1.2 as stated by the Meteohub system info. When set at 10.0.1.2, in the main window data appear, but they aren’t current data. They appear to be data from the past sometime, before the Weatherbridge was installed. I don’t understand the timescale on the graph, so am not sure. By the way, after changing the IP address to 10.0.1.2, WD now keeps it. If the address is changed to 10.0.1.16 and I quit WD, upon reopening, the address has returned to 10.0.1.2.
Also, in the Meteohub missed history data extraction window and this just started happening in Build 226, it looks like WD’s trying to get data from the future. The time is constantly changing.
Aloha,
Mark
Debug info got dropped.
@mswatanabe
you need to be entered the IP address to meteohub
not the Davis IP data logger
post a screen shot of setup where you are entering in WD
Hi Brian WD MacB226 quit logging data again at Noon wd was still running but not logging data. There were errors in the Program Event log. See post and Screen shoot. Restarted WD at 12:20 pickup all missing data.
Program Event Log WD Mac226
Access violation at address 008B3F48, accessing address 000000D8
Access violation at address 01A33985, accessing address 000002B8
ERROR: Access violation at address 018AC062, accessing address 0000029C at time/date 12:00 06/19/15
Btrip
