cloudy
Author Topic: pc with 2 lan port - ip camera  (Read 1011 times)
Offline Arnt
  • Norway - 65.52 N / 13.12 E
« on: August 07, 2011, 08:13:44 PM »
I have a pc with 2 lan ports.. can i use the second one for my ip camera?
Its a Stardot camera with dhcp etc (not recived it yet)..
Any experience with using pc's second lan port appreciated
Arnt
Offline NorCal Dan
  • Dan - KJ6RGX
  • Truckee, California
    • Traveling RV Weather
Re: pc with 2 lan port - ip camera
« Reply #1 on: August 07, 2011, 09:34:45 PM »
Sure you can use it, it's just another port.  But you will need to configure it for your application.  What OS are you running?  And does the camera need to connect to the internet, to accessible to visitors from the internet?  Much depends on your setup and what your plans are for the camera.
Offline Arnt
« Reply #2 on: August 08, 2011, 12:03:54 PM »
Going for a switch instead.. not sure why i got my mind set on that second port thing, when a switch should be much easier..
Offline arthurhh
  • Tokoroa Weather Live
  • IT Fixer
  • Tokoroa South Waikato New Zealand
« Reply #3 on: August 09, 2011, 02:22:36 AM »
The second port is easier and doesnt require more hardware, you just have to give it an IP in the range your using and go to town.
Offline Stronghurst
  • Burgus Weather
  • Stronghurst,IL USA
    • Burgus Computers
« Reply #4 on: August 09, 2011, 01:21:34 PM »
But you would also need a crossover cable.
Mark
http://www.burgus.org
Every day is a good day.  Some days are just better than others.
Offline NorCal Dan
  • Dan - KJ6RGX
« Reply #5 on: August 09, 2011, 03:11:19 PM »
As I said earlier, it depends on how you plan to use the camera and what requirements it has for IP.  Does the camera require a DHCP server to assign it an IP and other lease information?  Do you plan to have the camera online and allow visitors to connect to it?  What is your current internet connection, DSL, Wireless, Cable?
More info on the expected setup would go a long way towards being able to offer suggestions.
Offline Arnt
« Reply #6 on: August 12, 2011, 02:54:07 PM »
Win Xp, dsl.. i just want it to upload to my website.. no visitors will be allowed on the camera itself (at least not now).
But i will go for a try with the switch solution first.
Arnt
