cloudy
Author Topic: findu.com receiving data - but not updating?  (Read 3901 times)
Offline Peterjii
  • Seattle, WA
    • http://peterjii.homedns.org/weather/onlineweather.html
Re: findu.com receiving data - but not updating?
« Reply #15 on: August 01, 2011, 02:42:38 AM »
So I updated to build 59, it updated the findu page with my current data, just one time. Then it stops.
 The croncwop is dated 11/8/2008?
« Reply #16 on: August 01, 2011, 03:51:11 AM »
maybe check there is not another version of WD running , i.e that is 10.37 build 31
also, is there a 2wd.txt file in use or similar
ie a wdisplayftp2.ini in the registry, or similar?
Offline NorCal Dan
  • Dan - KJ6RGX
  • Truckee, California
    • Traveling RV Weather
« Reply #17 on: August 01, 2011, 04:31:22 AM »
Quote
CWOP data send start 10:25:11 PM 7/31/2011
APRS Connecting to: cwop.aprs.net
Aprs connected
sending pass command
user DW1695 pass -1 vers wx-display 10.37Q31
Sending the aprs data now
APRS data send:
DW1695>APRS,TCPIP*:@010525z3909.31N/12134.98W_171
/000g000t078r000p000P000b10110h51.WD 31
Disconnecting from the aprs server now
Finished
Here's my latest send...I don't think the string is updating as mine shows 31 as well when I' actually running 37Q59.
« Reply #18 on: August 01, 2011, 04:51:34 AM »
ops, my bad
31 refers to the station typoe (i.e Davis VP)
I will change that to the build number
its strange that for Peterjii the data updates once, on start up
but then not again
Peterjii, when WD is running (i.e live) are you sure the graphs are updating?
make sure you do not have set to share the data files
in the setup, advaneced/misc setup
and are there any errors under view, program event log?
Offline NorCal Dan
  • Dan - KJ6RGX
« Reply #19 on: August 05, 2011, 02:39:24 AM »
Looks good.
Quote
CWOP data send start 8:35:10 PM 8/4/2011
Aprs connected
user DW1695 pass -1 vers wx-display 10.37Q61
APRS data send:
DW1695>APRS,TCPIP*:@050335z3909.31N/12134.98W_170
/000g000t081r000p000P000b10108h49.WD 31
Finished
Offline NorCal Dan
  • Dan - KJ6RGX
« Reply #20 on: August 05, 2011, 02:43:24 AM »
Quote
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050152z4712.03N/12211.00W_018/000g001t076r000p000P000b10134h42.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050202z4712.03N/12211.00W_023/000g001t076r000p000P000b10134h42.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-2:@050212z4712.03N/12211.00W_184/000g001t076r000p000P000b10134h44.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-3:@050222z4712.03N/12211.00W_208/000g000t075r000p000P000b10135h44.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050232z4712.03N/12211.00W_122/000g000t075r000p000P000b10135h45.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050242z4712.03N/12211.00W_114/000g000t074r000p000P000b10136h50.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-3:@050252z4712.03N/12211.00W_114/000g000t073r000p000P000b10138h52.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-3:@050302z4712.03N/12211.00W_114/000g000t072r000p000P000b10138h51.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-2:@050312z4712.03N/12211.00W_114/000g000t071r000p000P000b10138h56.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050322z4712.03N/12211.00W_114/000g000t070r000p000P000b10139h57.WD 31
CW0672>APRS,TCPXX*,qAX,CWOP-1:@050332z4712.03N/12211.00W_114/000g000t069r000p000P000b10139h59.WD 31
My bad, I mis-read the time stamp on my other post...you are sending at 10 minute intervals  :oops:
It appears to be updating ok, are you still seeing problems on your end?
Offline Peterjii
  • Seattle, WA
« Reply #21 on: August 05, 2011, 03:05:23 AM »
Sorry, busy week didn't have time to respond back. But, yes everything seems to be working now. Not exactly sure what I did to get it working again...maybe it was the recent update/reinstall.
