cloudy
Author Topic: findu.com receiving data - but not updating?  (Read 3901 times)
Offline Peterjii
  • Seattle, WA
    • http://peterjii.homedns.org/weather/onlineweather.html
« on: July 28, 2011, 02:30:05 AM »
For some reason my CWOP data is not updating on findu.com. For example it says "last report from CW0672 received 1 second ago". (This is after I run a test and check data on CWOP setup page). But, data doesn't actually update? Temp stays stuck at 66F, but should read 64. Any ideas on settings I need to check on? Thank You.
Re: findu.com receiving data - but not updating?
« Reply #1 on: July 28, 2011, 02:41:39 AM »
is the data in WD update to date?
(i.e for the graph data)
also which version/build of WD?
Offline Peterjii
  • Seattle, WA
« Reply #2 on: July 28, 2011, 03:45:45 AM »
My version is 10.37Q Build 58. Yes, my WD data shows accurate and up to date info and charting. Been working for quite a few years up til now!
Thank You.
« Reply #3 on: July 28, 2011, 06:52:57 AM »
have you updated via a full install update?
i.e to get the latest croncwop.exe version
no problems here:
http://www.findu.com/cgi-bin/wxpage.cgi?DW0000
Offline Peterjii
  • Seattle, WA
« Reply #4 on: July 28, 2011, 02:32:16 PM »
The 'croncwop.exe' version I have is dated 11/8/2008. As a test I  renamed the file I had, re-installed the full install and it gave me a new file (still dated 11/8/2008). I opened CWOP control panel switched it to off, closed everything, opened it back up, switched it to "on", hit the TEST button. I checked my data and it updated! I thought all was now working. 10 minutes later I'm back to my old problem. CWOP indicates a recent upload, but the data is now stuck  - i.e. the temperature is stuck on the 53 degree mark.
« Reply #5 on: July 28, 2011, 07:02:33 PM »
check the actual data being sent
in the registry
wdisplayftp.ini
[Aprs data send]
data=
is changing
Offline Peterjii
  • Seattle, WA
« Reply #6 on: August 01, 2011, 01:35:23 AM »
I've attached two screen shots of the registry, the second after a "test" upload of data to CWOP. It changes slightly, but the temp data, etc isn't updating.
« Reply #7 on: August 01, 2011, 01:38:00 AM »
is the graphs updating OK in WD?
also make sure you do not have set "create positionless"
in the setup, create aprs file
Offline Peterjii
  • Seattle, WA
« Reply #8 on: August 01, 2011, 01:41:16 AM »
In addition, here the contents of the cwop log file:
CWOP data send start 7:32:05 PM 7/31/2011
APRS Connecting to: cwop.aprs.net
Aprs connected
sending pass command
user CW0672 pass -1 vers wx-display 10.37Q31
Sending the aprs data now
APRS data send:
CW0672>APRS,TCPIP*:@010232z4712.03N/12211.00W_000/
000g000t053r000p003P000b10225h00.WD 31
Disconnecting from the aprs server now
Finished
stuck on 53 degrees, etc
Offline Peterjii
  • Seattle, WA
« Reply #9 on: August 01, 2011, 01:42:44 AM »
That is set to "NO".
Offline Peterjii
  • Seattle, WA
« Reply #10 on: August 01, 2011, 01:46:33 AM »
If it makes any difference, my weather display live page is updating correctly.
Offline Peterjii
  • Seattle, WA
« Reply #11 on: August 01, 2011, 01:50:23 AM »
...also, yes, the graphs on the main screen are updating OK
« Reply #12 on: August 01, 2011, 02:10:57 AM »
I see it says you are using build 31?
I would use the latest full install version
try that instead
Offline Peterjii
  • Seattle, WA
« Reply #13 on: August 01, 2011, 02:31:46 AM »
Hmm, my screen says Ver 10.37Q Build 58 at the top.
The program is running out of c:\wdisplay
I do see the 31 in the log, though...??
« Reply #14 on: August 01, 2011, 02:35:05 AM »
are you using the latest croncwop.exe version included in the full install?
