cloudy
Author Topic: A problem with WD just popped up  (Read 3407 times)
Offline Terry
« on: July 12, 2011, 06:31:12 AM »
Howdy I'm running WD version 10.37p on Windows server 2003, and a problem has come up.
Every time the data received count gets above 58,000 WD will lock up, I have to use task manager to stop the program and re-start.
This has started about a week ago, and is an regular problem.
Photo is of the program when it's froze up.
Re: A problem with WD just popped up
« Reply #1 on: July 12, 2011, 08:22:54 AM »
I would use the latest version
10.37p is an old version
Offline Terry
« Reply #2 on: July 21, 2011, 04:16:32 AM »
OK have down loaded the file on the 12th and file installed the same day, it locked up today at about 8PM my time.
Any ideas?
« Reply #3 on: July 21, 2011, 07:17:50 AM »
so 9 days later?
what was the counter up to?
what weather station type?
what antivirus program are you running?
how much memory on the pc?
Offline Terry
« Reply #4 on: July 22, 2011, 07:01:47 PM »
Counter was up to 53,670. (last time it locked up at 58 K +)
Peet Bro's 2000 weather station.
AVG pro for server, Malwarebytes, Spybot SD.
4 GB ram, 5ea 2 TB hard drives.
« Last Edit: July 22, 2011, 07:04:13 PM by Terry »
« Reply #5 on: July 22, 2011, 07:12:36 PM »
is that in complete record mode?
Offline Terry
« Reply #6 on: July 23, 2011, 06:24:01 AM »
Yes the weather station is in complete record mode, should it not be?
Offline Terry
« Reply #7 on: July 25, 2011, 09:33:48 PM »
Locked up again, this time at 56976 on the counter...........at around 6:47 AM
« Reply #8 on: July 27, 2011, 01:30:10 AM »
any other Ultimeter users with complete record mode have this problem?
how long was WD running before this occurs?
also, under setup, advanced/misc, try not having set to log the raw data  if that is set
Offline Terry
« Reply #9 on: July 30, 2011, 04:50:37 PM »
OK I will check those settings.
Hummmm and as far as how long WD has been running, it runs 24/7 365, it has run for 6 years straight. (Except for a few weeks when the main PCB died in the server)
Also it locked up again last night around Midnight, counter at 56,789, so It not a time related issue, but when that counter gets above 52 K.
« Last Edit: July 30, 2011, 04:53:38 PM by Terry »
« Reply #10 on: July 30, 2011, 10:00:02 PM »
what I mean by time, is, how long does it take, time wise, before the problem occurs, after WD is started?
Offline Terry
« Reply #11 on: August 01, 2011, 03:58:10 AM »
Time wise about 200 to 220 hours, I can time it a bit closer next time.
« Reply #12 on: August 01, 2011, 04:54:39 AM »
so you mean something like 9 to day 10 days?
have you tried monitoring the memory use by WeatherD.exe and other programs on the PC (using task manager)
Offline Terry
« Reply #13 on: September 26, 2011, 04:58:46 PM »
OK have watched this for a bit, it's every 200 hours to lockup, I have tried changing the clock on the server, (back 5 hours) that did nothing, the memory usage is normal, WD exe is using 1% of the CPU time and 35 K of memory on the server out of 4 GB so there is not a memory problem.
Here is a copy of the program error log if that will help.
Offline Terry
« Reply #14 on: October 11, 2011, 10:06:08 PM »
Locked up again right at the 200 hour mark, any ideas on this one guys?
What can I do to keep a log of this problem to send to you for eval?
