cloudy
Author Topic: Dallas 1-wire reader program [RESOLVED]  (Read 4599 times)
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« on: June 05, 2011, 06:14:11 AM »
I have just upgraded from 37Pb41 to 37Qb44 and find that I now have the dallas 1-wire reader starting when WD starts. The issue is that I dont have any 1-wire stuff (I have a Davis station), and I cant see why this is starting up as it is not needed. Anyone know why I am seeing this? It must be an old setting somewhere as years ago I did have a 1-wire lightning detector (no longer used or connected).
Edit: It would seem that this program starts at WD start and then terminates if there is nothing to do. I was a little confused by seeing it initially. Is this correct operation?
« Last Edit: June 12, 2011, 09:35:38 AM by windy »
Offline broadstairs
  • Stuart
    • Broadstairs
Re: Dallas 1-wire reader program
« Reply #1 on: June 12, 2011, 05:48:43 AM »
Well I am even more confused now, I had to restart WD the other day after moving the PC to another room and after the reboot the Dallas 1-wire reader started up again and is still running some days later, it is using CPU every few seconds - not much but it is using it - and I have no 1-wire instruments at all. How can this be right, why is this thing running on a system without 1-wire? I tried viewing it but there is no apparent way to close it down cleanly and I'm loathed to close it forcibly in case it screws something up. Is there a setting I've missed somewhere which I need to turn off?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #2 on: June 12, 2011, 08:40:00 AM »
Quote
huh?
just close it, via the X top right
it will be no problem
it will only start up if you have set to use a 1 wire sensor
you must have that set (e.g in the com port setup, use 1 wire as well)
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #3 on: June 12, 2011, 09:28:34 AM »
Thanks Brian, I thought I'd turned it off in the right places but there was one tick box left. Long time since I did the lightning stuff so was not very familiar with it. Now does not start up.
Thanks again Stuart
  • Davis VP2
  • New Zealand
    • Weather Display
Re: Dallas 1-wire reader program [RESOLVED]
« Reply #4 on: June 12, 2011, 09:36:03 AM »
make sure to be using the latest version of WD too....
Offline broadstairs
  • Stuart
    • Broadstairs
« Reply #5 on: June 12, 2011, 10:40:13 AM »
I'm on 37Q b44 at the moment..... I hae a problem which I nknow is one of my making at the moment and so I wont update WD again until I sort it.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #6 on: June 12, 2011, 06:27:32 PM »
I recommend to use the latest version
Offline Nanasmet
  • Hajdúnánás, Hungary
    • www.nanasmet.hu
« Reply #7 on: June 13, 2011, 06:58:48 PM »
Someone tell me why the leaf sensor uv?
Wd settings in the leaf during a UV sensor should be?
I think some programming error in the wire dallas SOFTWARE 3.4, 3.5, 4,0 Series is that it works.
Solar is working every versions but uv sensor not working I think that problem.
Who can help?
« Last Edit: June 13, 2011, 07:00:54 PM by Nanasmet »
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #8 on: June 13, 2011, 07:14:34 PM »
do not worry about the ini file settings
does it really matter how I have done the naming convention?
(its grouped under similar type sensors)
your UV sensor is returning an error
I have tested my UV sensor and that is working
Offline Nanasmet
    • www.nanasmet.hu
« Reply #9 on: June 14, 2011, 05:01:14 AM »
hello
Then what do I do to work out the UV sensors.
I do not understand what could be the problem. Now the sensor is bad?
I think if I write once a UV sensor on the identity of the INI file should go there too. I have tried everything but it seems that the software problem.
Finally someone who knows and understands when to send me email to improve the repaired wire dallas newest reader software.
Thanks Nanasmet
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #10 on: June 18, 2011, 08:58:57 PM »
do you have set thats its a hobbyboards uv sensor in WD in the 1 wire setup?
I have added that option to the dallas1wirereader now
update:
http://www.weather-display.com/downloadfiles/dallas1wirereader.zip
Offline Nanasmet
    • www.nanasmet.hu
« Reply #11 on: June 19, 2011, 09:23:51 AM »
Already tried the latest version, it does not work. 4.1 did not go.
I really do not understand what's wrong, I tried everything.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #12 on: June 19, 2011, 06:14:03 PM »
did you select the hobbyboards UV setting?
Offline Nanasmet
    • www.nanasmet.hu
« Reply #13 on: June 20, 2011, 06:07:08 PM »
Yes, I have chosen.
Thursday, reinstall system and re-configure everything. If you can not go to the trash you throw all of my wire sensor. I do not know what I'm doing it.
I tried everything I thought I could wire the driver has a problem, but I can not find an older version. install_1_wire_drivers_x86_v403.msi above, but is now trying to have a install_1_wire_drivers_x64_v403.msi version.
The configuration should go as:
     Motherboard Name: Intel D945GCLF Little Falls
     Intel Atom 230, 1600 MHz (12 x 133)
     System Memory: 1024 MB (DDR2-800 MHz)
     Chipset: Intel 82945G Express Chipset Family
     3D Accelerator: Intel GMA 950 (128MB)
     Hard Drive: SAMSUNG HM121HI (120 GB, 5400 RPM, SATA)
Windows XP SP3 x86
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #14 on: June 24, 2011, 02:30:21 AM »
does the 1 wire viewer find and work with the uv sensor?
is it a hobbyboards UV sensor?
