The Mantis Bug Tracker is linked with the Forum such that if you’re logged into the Forum you can directly access Mantis without having to log in. I need to upgrade Mantis to a more recent version and the Forum/Mantis integration code will probably need significant changes to make it work.
So I’m proposing to make the following change…
- The link to Bug Tracker in the Forum will still take you to Mantis, but you won’t be logged in.
- You will be able to log into Mantis with the same username/password as you use on the Forum.
- I will modify the existing sync script to create a new Mantis user for each forum user and also to sync user details/email addresses from the Forum into Mantis on a regular basis.
I’ll be making this change in the next few days and will post again when it’s been done.
