cloudy
Author Topic: iPhone weather app - Under the Weather  (Read 8494 times)
Offline undertheweather
« on: May 05, 2011, 03:51:10 AM »
Hi all,
I have almost completed an iPhone weather app for personal weather stations. Please view;
www.undertheweather.co.nz for more info and screenshots of the upcoming release.
You may also submit your weather station to be included in the app absolutely free! At present I am all
set up for Cumulus weather stations however I am adding in other software as I get to it - please submit whatever you have.
Ben
Re: iPhone weather app - Under the Weather
« Reply #1 on: May 05, 2011, 04:32:34 AM »
It would be good if you could add support for the WD clientraw.txt file
(there is a description of that file data format in the clientrawdescription.txt included in the WD software)
since this is a WD support forum  :wink:
« Reply #2 on: May 05, 2011, 04:54:29 AM »
Thanks Brian, just downloading your software now - will add support as you suggested. The aim is to support all software.
Cheers, Ben
« Reply #3 on: May 05, 2011, 05:45:38 AM »
sounds great
I like the idea of graphs that you mention will be available
Offline jwwd
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
« Reply #4 on: May 05, 2011, 08:24:04 AM »
What a great idea - I have submitted my site - but was not able to set the location of my clientraw.txt file.
If you are interested, I can help you translate into Danish.
Henrik
Offline JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
« Reply #5 on: May 05, 2011, 11:21:36 AM »
Submitted mine as well but would need to add the clientraw location as Henrik mentioned...
Offline Smithee
« Reply #6 on: May 05, 2011, 12:03:10 PM »
Yep sent in Central London  :)
http://www.casa.ucl.ac.uk/weather/lcdipad22.html
Andy
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #7 on: May 05, 2011, 12:46:16 PM »
Hi all,
Ben
Sure hope you intend to port to Android?
Offline vk2him
  • Gerringong, NSW, Australia
    • The Shack by the Beach
« Reply #8 on: May 05, 2011, 08:00:43 PM »
Do we get a free copy of this app if we submit our weather data, after all you are making money from this app by using our data  8)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #9 on: May 05, 2011, 08:36:11 PM »
Good questions...
Also are you caching the data or is the app going to hit these guys' websites directly?
« Reply #10 on: May 05, 2011, 10:23:29 PM »
Good questions from the 2 above posts - We intend to sell the app for approx. $2.59 NZD or whatever the equivalent in local currency.
This should cover some of the development costs and ongoing releases but I suspect won't get anywhere near break even!!
The app is aimed to bring together weather stations from around the world and share as a 'community' - should you wish to be part of this community please submit your app - if not, please don't.
The app is not making calls on your own website / server - I am saving data at my end into a database everytime you process the php file and when someone views the app it is making a call on my server.
Hope this clears up a few things.
Thanks, Ben
« Reply #11 on: May 05, 2011, 10:28:47 PM »
Also to answer the question of do you receive a free copy of app if you submit your station - I'm trying to however Apple rules
only allow a maximum of 50 promo codes per app so that won't work.
So at this stage I can't promise anything however I will see if there is a workaround for this Apple rule.
Thanks, Ben
Offline niko
  • syzygy
  • Global Moderator
« Reply #12 on: May 05, 2011, 10:29:05 PM »
Sounds good, thanks for the info  :D
Offline vk2him
« Reply #13 on: May 07, 2011, 12:43:14 AM »
Thanks, Ben
Ben,
The work-around is that the 50 promo codes is per version release, so every version you release can have 50 promo codes  ... from an Apple developer forum is the following:
Quote
Also, developers can reset their 50 code limit by releasing an update to their application.
Cheers
« Reply #14 on: May 07, 2011, 01:37:40 AM »
Yes thanks for that - I had discovered that last night - I will work out a system whereby - the first 30-35 or so for each release get a free copy
of the app. I need a few for promo / marketing. Rest should be fine.
I'll post figures on the website - www.undertheweather.co.nz
Thanks, Ben
