General > Forecasting
Which Charts
Budgie:
I'm sure the RAOB data is only available for the U.S, hence we don't use it for WXSim.
You can get some of the scritps from the DA Forum, I've posted the script I use for all the charts on my site. If you use that script then you'll have to change a few things like the location of the maps and the overlay files as they are specific to my own setup but the scripting itself will work fine.
DA Scripting Forum. :wink:
embayweather:
Just had a reply from them and it will analyze European data. You can in fact do a little of it with DA in the Soundings section, RAOB just takes it further. there is a Lite version for around £30 which might be worth a go to try it. I do find that the lack of decent plotted Sonde charts that are easily obtainable a big drawback.
I will look on the forum about scripts as you suggest. My understanding of such things is limited but I will try and give it a go before the silly season starts for me again.
Best wishes
Mike
Budgie:
It's actually not that bad once you figure out what the script is doing.
There are basic commands like "REMOVE" to delete the current map, "LOAD" to load a new map, "download" to download the data.
There's good instructions and the forum has answers to most questions.
Navigation
[0] Message Index
[*] Previous page
Go to full version
