cloudy
Author Topic: CWOP, WU, and WB not uploading  (Read 5906 times)
Offline Abacela
  • Ashland, Oregon USA
    • SOU: Ashland Weather Station
« on: January 23, 2011, 01:28:32 PM »
I followed all WD and CWOP (DW6803), WeatherUnderground (KORASHLA12), and WeatherBug (21507) instructions for posting my station, including having the main FTP switch on. I can see that the WD ftp starts up and send data every 5 minutes, but nothing ever gets to CWOP, WU, or WB. Must be something blocking it, but I can't locate any specific issue and other ftp processes work fine.
Any ideas on a flow to figure out what is happening?
Greg
Offline JaxWeather
  • Bob
  • Global Moderator
  • VP 2 w/FARS - WML Station: WD00007
  • Jacksonville, Fl. USA
    • JaxWeather.net
Re: CWOP, WU, and WB not uploading
« Reply #1 on: January 23, 2011, 01:38:21 PM »
Greg,
Both WU and CWOP typically have a delay between sending your first data and appearing live.
How long has it been?  What are your WU and CWOP station ID's?
Offline Abacela
« Reply #2 on: January 23, 2011, 02:35:31 PM »
Bob,
Its been nearly two weeks now. I have contacted CWOP and they said my station is registered fine, but no data comes across.
Greg
Offline JaxWeather
  • Bob
  • Global Moderator
    • JaxWeather.net
« Reply #3 on: January 23, 2011, 06:40:20 PM »
What does your FTP log show when an upload is supposed to occur?
Offline Abacela
« Reply #4 on: January 25, 2011, 01:56:15 PM »
Bob,
My ftplog shows the following:
FTPUPD.EXE finished at 1:05:08 AM 1/24/2011
Time taken = 0.02 minutes
Total bytes uploaded =  0 K
Total bytes uploaded for the day = 0.00 Mb
Total bytes uploaded for the month = 0.09 Mb
FTPUPD.EXE started at 1:10:06 AM 01/24/11
****agenda items to do...****
dowunderground
doweatherbug
*******list of files uploaded********
FTPUPD.EXE finished at 1:10:12 AM 1/24/2011
Time taken = 0.03 minutes
FTPUPD.EXE started at 1:13:02 AM 01/24/11
do aprs data send
So it appears that the ftp is setup to upload, but that nothing is posted. Not sure why? Attached below and in other replies are a couple of screen shots of my setup for CWOP/APRS and the ftp main.
Greg
Offline Abacela
« Reply #5 on: January 25, 2011, 02:08:41 PM »
CWOP-APRS setup
Offline Abacela
« Reply #6 on: January 25, 2011, 02:16:14 PM »
Main ftp setip
Offline NorCal Dan
  • Dan - KJ6RGX
  • Truckee, California
    • Traveling RV Weather
« Reply #7 on: January 25, 2011, 05:30:04 PM »
It appears you are using a CWOP ID, try unticking that...
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
« Reply #8 on: January 25, 2011, 06:10:55 PM »
I see you have checked that you are not using a CWOP ID, is this true. Your ID of DW6803 looks like a proper CWOP ID (mine is DW2671). Are you in fact registered as a Ham ID with CWOP? If not, then maybe try deleting the id in the Ham Validation box and uncheck the box stating you are not using a cwop id.
Also, on your server setup you have checked Use this server instead, but there is no server selected. Uncheck that box as well as another thing to try.
« Last Edit: January 25, 2011, 06:14:23 PM by mfd38 »
Offline Abacela
« Reply #9 on: January 26, 2011, 09:38:09 PM »
Did everything suggested in the last two replies (thanks by the way) and the ftplog still shows
FTPUPD.EXE started at 12:53:01 PM 01/26/11
do aprs data send
FTPUPD.EXE finished at 12:53:07 PM 1/26/2011
FTPUPD.EXE started at 12:55:02 PM 01/26/11
dowunderground
doweatherbug
FTPUPD.EXE finished at 12:55:08 PM 1/26/2011
Since nothing is being uploaded then WD must not be reading or processing a file. How can I check to see if WD has what it needs to post?
Help ... Greg
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #10 on: January 26, 2011, 10:04:52 PM »
Uncheck the "internet sharing over a LAN" in the FTP setup.
Offline Abacela
« Reply #11 on: January 28, 2011, 06:50:07 PM »
Thanks ... that seemed to do the trick for CWOP-APRS and WeatherBug ... however, WeatherUnderground is still not posting. Any tricks with it that might different from the other two.
Greg
« Reply #12 on: January 28, 2011, 09:48:31 PM »
not sure why people tick that internet sharing over a LAN
I think I might disable that
its very rarely needed
as for wunderground, it says its uploading
double check you have the ID and password set correctly (they are case sensitive)
Offline Abacela
« Reply #13 on: January 29, 2011, 07:48:53 PM »
Thanks Brian ... not sure why I checked the LAN ??
CWOP-APRS and WB working fine, but WU still not posting. I have the station and password set up fine and the station exists on wunderground, nothing gets to them. No luck with anyone at WU to confirm that the station is setup to receive on their end. Any other ideas?
Cheers,
Greg
« Reply #14 on: January 29, 2011, 09:03:55 PM »
most often people say they have the WU ID and password set correclty when in it turns out that it is not
also do you have WU rapid fire in use?
