Weather Equipment/Software > Tinplate Software
Virtural VP Error in activity log.
(1/2) > >>
jjmcnelly:
Any ideas what this error means?  does it every 2 seconds or so
16:15:14:329 PreCondition - TVirtualVp.ReceiveLoop: PreCondition 1 failed
16:15:14:344 Error        - Output buffer too small for block
James
ullises:
I have the same errors on my PC....but only when i use WD - alone or togheter with VWS , WL , Cumulus and so on...If i use any soft except WD is all fine....this happens under Wxp and W7...
broadstairs:
I remember seeing tis when I have been testing WD with VVP but to be honest I cant remember if it was virtual com port I was using or direct TCPIP. What are you using? If its direct TCPIP I'd expect it to be a WD problem not providing a large enough buffer but I wait to be proved wrong on that! I will watch out for that when I next test it. On my live system I use a virtual com port with an old build.
ullises:
is on com port...and i tried on 2 laptops and one desktop , on windows7 and windows Xp...32x and 64x...is the same all over...strange thing is that VWS , cumulus and WL are working just fine...problems start when is WD involved here...i will try an old version of WD and hope for the best...
jjmcnelly:
I was using tcp/ip.
--- Quote from: broadstairs on January 23, 2011, 05:05:46 PM ---I remember seeing tis when I have been testing WD with VVP but to be honest I cant remember if it was virtual com port I was using or direct TCPIP. What are you using? If its direct TCPIP I'd expect it to be a WD problem not providing a large enough buffer but I wait to be proved wrong on that! I will watch out for that when I next test it. On my live system I use a virtual com port with an old build.
--- End quote ---
Navigation
[0] Message Index
[#] Next page
Go to full version
