If I reboot My computer for some reason I have 2 versions Of WD wanting to start when I reboot. WD is also listed twice in my startup menu in msconfig. Can I just untick one? Delete one . I always make a backup of WD when I upgrade and place on desktop. could that be the reason?
It is probably built into the Startup menu and best to delete from there;
I only know about Win XP so it may differ in later OS versions… YMMV
Go to Explorer and C:\ Documents and Settings\ Username (Brad say) \ Start Menu \ Programs \ Startup \
and delete it from there if it is in there. I believe WD will put it into Registry [Run] section automatically/directly if ticked under Setup - Launch when Windows starts but it may have gotten in at two places.
If it is not there, then it may be there under Default - instead of your username - same path. Or it may have been entered in both places…
