cloudy
Author Topic: Davis Vantage Pro 2 - separating rain bucket and temp on ISS  (Read 3009 times)
Offline kaimaikid
  • It was this big....
  • Tauranga, New Zealand
    • Welcome Bay Weather
« on: October 29, 2010, 04:25:35 PM »
I haven't looked as yet but is it possible to remove the temp sensor or rain gage from the ISS on a cabled Davis Vantage Pro 2 6152C ?
As I wish to mount the temperature sensor separately from the rain bucket due to getting high temp readings during the day however need to leave the rain bucket where it is.
Offline iomkiwi
  • Kerikeri, Bay of Islands, NZ
    • Kerikeri Weather
Re: Davis Vantage Pro 2 - separating rain bucket and temp on ISS
« Reply #1 on: October 29, 2010, 05:42:22 PM »
You could just extend the cable from the rain bucket. Otherwise I "think" you can do it with the anemometer transmitter kit if you want/need it to be wireless. (I asked a similar question to Davis but never got a reply)
Either way you would need to get a new base plate for the rain bucket assembly.
Offline chucl1932
  • Tehachapi, California
    • Tehachapi(Golden Hills) California
« Reply #2 on: October 29, 2010, 05:55:05 PM »
You may be better off getting a fars unit for your iss unit. I installed one on mine and have very good temp readings from then to now.
Chuck
Offline kaimaikid
« Reply #3 on: October 29, 2010, 08:24:39 PM »
Just had a look inside the ISS board box it, both the temp/hum sensors and rain sensor are plug ins as to being hard wired, the temp/hum unit is just held on to the bottom of the bucket by 3 screws making it simple to detatch, so hopefully by adding an extention cable to the temp/hum sensors won't alter the readings by adding extra resistance from a longer cable...
EDIT: Might be safer to extend the rain lead by moving the board box with the temp/hum sensors.
« Last Edit: October 29, 2010, 08:42:27 PM by kaimaikid »
Offline Budgie
  • Martin
  • Global Moderator
  • WML Station: WD00934 CWOP: CW7959
  • Isle of Lewis, Scotland
    • Hebrides-Weather
« Reply #4 on: October 29, 2010, 09:50:52 PM »
I think I'd save all the hassle and go with Chuck's suggestion: Daytime FARS
I use this and it does make a difference in keeping the daytime temps in check.  :wink:
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #5 on: October 29, 2010, 09:57:07 PM »
Much better idea.
You can get another rain gauge base and use that to mount the electronics box and the shelter, or it's not too difficult to make a mounting.
Offline kaimaikid
« Reply #6 on: October 29, 2010, 10:01:05 PM »
Biggest problem that I have is the terrain where I live, the perfect place for the temp sensor is no good for rain, but alas, will have it all sorted very soon once I get myself motivated  :wink:
Offline jerryg
  • welcome to my world of weather
  • Victoria, Texas
« Reply #7 on: October 30, 2010, 07:35:13 PM »
i have my 6152c completely apart so i could put my anny up at 33 feet on my tower. I put the iss box inside workshop and ran cat 5 out to the sensor which i have in a fars located about 50 feet from the iss box and the temp/hum reads right on. I have the rain guage about 40 feet away and just used a two conductor wire with connectors on each end, one with a splice at the rain gauge end sealed and the other plugged into the iss. I have all the devices in the best spots possible. All works the same as if it was together.
Offline kaimaikid
« Reply #8 on: October 30, 2010, 10:46:09 PM »
Darn, wished I knew that the temp/hum sensor cable could handle being extended as then I could have left the ISS more central allowing me to put up the wind anny higher... #-o
ah well....   :lol:
Offline kaimaikid
« Reply #9 on: November 06, 2010, 06:55:46 AM »
ok, a couple of piccys of my set up
The temp/hum sensor is on the southern end of the house above grass where it virtually never gets any direct sun and the wind sensor is about 5m above the roof, I changed it all around again separating the temp/hum from the ISS so that I can add a solar sensor at some stage.
« Last Edit: November 07, 2010, 03:48:04 PM by kaimaikid »
Offline beun.net
  • Hilversum, The Netherlands
  • Win 7/Srvr 2008R2
  • Chrome 16.0.912.75
    • Meteo Hilversum
« Reply #10 on: January 16, 2012, 03:18:39 PM »
ah well....   :lol:
*kicks old topic*
What is the length of the cable going to your temp/hum sensor?
I'm thinking about doing the same to my Vantage Pro2 Plus (6162). Wind/UV/Solar/Rain are all up on the roof. Best place for all those sensors in my case. It's just the temp/hum sensors that should go somewhere else. Preferably in my garden, about two meters above the grass or so. At least not up on the roof.
But to make this happen, I would have to extend the temp/hum cable about 15 meter... Any idea whether or not that would work?
« Last Edit: January 16, 2012, 03:25:20 PM by beun.net »
The Meteo Hilversum website: http://meteohilversum.nl
The Meteo Hilversum Twitter account: http://twitter.com/MeteoHilversum
Offline prodata
  • Cambridge, UK
  • Win Vista/Srvr 2008
    • Automatic Weather Stations
« Reply #11 on: January 16, 2012, 03:56:20 PM »
There's a debate going on about this elsewhere currently. Davis say, no - don't do it (because there's no signal conditioning on the relevant SIM input adequate to cope with long T/H cables - it was only ever designed to accommodate short cables).
But some users are apparently using longer extension cables and getting away with it.
I think the problem here is that long T/H cables are clearly not a recommended or supported option. But it may work nonetheless. The problem as I see it is that while it may well work in the sense of still getting T/H readings, you may very probably lose confidence in the accuracy of those readings. To be on the side side, the best advice is not to lengthen the T/H cable.
John Dann
www.weatherstations.co.uk - UK Davis specialists
VP Knowledgebase Curator - see http://vp-kb.wikispaces.com
Offline N7XSQ
  • Phoenix, Arizona
  • Win XP
  • Firefox 3.6.25
« Reply #12 on: January 18, 2012, 06:55:15 PM »
The ISS mounting bracket/plate is available as a a replacement part.
This part can be used to make separation of the rain bucket from the ISS relatively easy.
The rain bucket cable can be extended quite a ways, while it is not recommended to extend the temp/humidity cable
See this post and the rest of the thread:
http://www.weather-watch.com/smf/index.php/topic,26187.15.html#msg206847
Steve
Offline jerryg
  • Victoria, Texas
  • Win XP
  • MS IE 8.0
« Reply #13 on: January 21, 2012, 01:51:56 AM »
Like i said above i ran my t/h sensor around 50 feet using cat5 cable and it was just fine. The sensor outputs a digital signal so as long as the signal reachs the sim it is accurate, the only possible problem i see is if the voltage drop down the cable got low enough to not power the sensor. Just my observations here.
Offline aardvark
  • I am perfectly calm,ready to hear your opinion
  • Des Moines, Iowa, USA
  • Win 7/Srvr 2008R2
  • MS IE 9.0
    • Des Moines, Iowa Weather
« Reply #14 on: January 21, 2012, 06:19:04 PM »
I would have two major concerns.  First, separation will void your warranty, but then who cares?   Second, will the temperature difference be that significant from moving the radiation shield off the rain collector floor and placed in, I assume, a similar shield elsewhere.
You can always do anything you can, with a wireless, but with a cabled, you need a way to run your wires to the transmitter, being concerned about length restrictions, water tight connection between the sensor cables and plugs. Protection of your cables from the elements.  All will make a great project for you, good luck... have fun.
VP2, Daytime Fars, Solar/UV; Soil station; extra temp/humid station; extra temp stations; Windows 7, 8G Ram , 1TB drive/external and Windows xp for weather data.
